Intel Atom D2550处理器, 6*COM, 1* LAN, 背置CPU, 2*Mini-PCIe
| General | |
| CPU |
Intel® AtomTM D2550 CPU, Dual-core, 1.86 GHz, TDP 10W |
| Chipset |
Intel® NM10 Chipset, TDP 1.5W |
| Memory |
Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM |
| Storage |
1*SATA 2.0, 1*mSATA |
| Expansion Interface |
2*Mini-PCIe (1* Wifi/3G/4G Supported, 1* mSATA Supported) |
| BIOS |
AMI UEFI BIOS |
| System |
Windows XP/7, Linux |
| I/O Interface | |
| Serial Port |
6*RS232 (COM5 RS485 or TTL optional) |
| USB |
8*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet |
1*Realtek® PCI-E LAN for 1000Mbps |
| Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 |
1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port |
1*LPT |
| GPIO |
8 programmable GPIO |
| Feature Interface |
1*FPC |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display |
Dual |
| Mechanical & Environment | |
| Dimension |
3.5", 146*105mm |
| Power Input |
DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
