信步科技SV1-D4212主板规格英文版
Intel Atom D425处理器, 2*COM, 1*LAN, 1*PCI, 1*Mini-PCIe, 可搭配DC 12V电源模块
  • 采用Intel Atom D425处理器
  • 采用Intel NM10芯片组
  • 提供2*COM, 8*USB, 1*百兆LAN
  • 提供VGA, 可搭配信步SV-M2-GL子卡,组成多种双屏异显 (VGA+LVDS/VGA)
  • 提供1*PCI, 1*Mini-PCIe (支持3G/4G/Wifi)
  • 可搭配信步DC 12V电源模块
规格
General
CPU Intel® AtomTM D425 CPU, Dual-core, up to 1.8GHz,TDP 13W
Chipset Intel® NM10 Chipset, TDP 1.5W
Memory Up to 4 GB DDR3 800 MHz, 1*SO-DIMM
Storage 2*SATA 2.0
Expansion Interface 1*PCI, 1*Mini-PCIe (3G/4G/Wifi Supported)
BIOS Phoenix BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 2*RS232
USB 8*USB 2.0 (4*on rear I/O, 4*header)
Ethernet 1*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 7 programmable GPIO
Feature Interface Null
Display
Display Interface 1*VGA: max resolution up to 2048*1536@60Hz
Multiple Display Single
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
嵌入式主板
嵌入式主板
