信步科技SV1-25526主板规格英文版
Intel Atom D2550处理器, 6*COM, 2*LAN, 1*PCI, 1*Mini-PCIe, 可搭配DC 12V电源模块
  • 采用Intel Atom D2550处理器
  • 采用Intel NM10芯片组
  • 提供6*COM, 7*USB, 2*百兆LAN
  • 提供1*VGA, 1*LVDS,支持双屏异显
  • 提供1*PCI, 1*Mini-PCIe
  • 可搭配信步DC 12V电源模块
规格
General
CPU Intel® AtomTM D2550 CPU, Dual-core, 1.86 GHz, TDP 10W
Chipset Intel® NM10 Chipset, TDP 1.5W
Memory Up to 4 GB DDR3 1066/800 MHz, 1*SO-DIMM
Storage 2*SATA 2.0
Expansion Interface 1*PCI, 1*Mini-PCIe (Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows XP/7, Linux
I/O Interface
Serial Port 6*RS232 (COM3 TTL, COM6RS485 optional)
USB 7*USB 2.0 (4*on rear I/O, 3*header)
Ethernet 2*Realtek® PCI-E LAN for 100Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1*LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*LVDS: Single Channel 24bit, max resolution up to 1440*900@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
