信步科技SV1-H811A主板规格英文版
Intel 4代Core i3/i5/i7处理器(LGA1150), 10*COM, 1*LAN, PCI-E 16X, 1*Mini-PCIe
  • 支持Intel 4代CoreTM i3/i5/i7处理器(LGA1150)
  • 采用Intel H81芯片组
  • 提供10*COM,9*USB, 1*千兆LAN
  • 提供1*VGA, 1*HDMI, 支持双屏异显
  • 支持VTM异步输出电路,支持板上语言切换
  • 提供1*PCI-E 16X, 1*Mini-PCIe
规格
General
CPU Intel® Pentium®/ Celeron®/ 4th Generation CoreTM i3/i5/i7 CPU, LGA1150
Chipset Intel® H81 Chipset, TDP 4.1W
Memory Up to 16 GB DDR3 1600/1333 MHz, 2*DIMM
Storage 2*SATA 3.0, 1*SATA 2.0
Expansion Interface 1*PCI-E 16X, 1*Mini-PCIe (Wifi/3G/4G Supported)
BIOS AMI UEFI BIOS
System Windows 7/8/10, Linux
I/O Interface
Serial Port 10*RS232 (COM2 RS485 optional)
USB 2* USB 3.0, 7*USB 2.0 (4*on rear I/O, 5*header)
Ethernet 1*Realtek® PCI-E LAN for 1000Mbps
Audio Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts
PS/2 1*PS/2 (Keyboard and Mouse Supported)
Parallel Port 1* LPT
GPIO 8 programmable GPIO
Feature Interface Null
Display
Display Interface
1*VGA: max resolution up to 1920*1200@60Hz
1*HDMI: max resolution up to 1920*1200@60Hz
Multiple Display Dual
Mechanical & Environment
Dimension Mini-ITX, 170*170mm
Power Input ATX PSU
Temperature Operation: 0℃~60℃, Storage: -25℃~75℃
Relative Humidity Operation: 10%~90%, Storage: 5%~95%, non-condensing
WINDOWS
WINDOWS
