Intel Celeron 1037U处理器, 10*COM, 1*LAN, 1*PCI-E 16X, 2*Mini-PCIe
| General | |
| CPU | Intel® Celeron® 1037U CPU, Dual-core, 1.8 GHz, TDP 17W |
| Chipset | Intel® NM70 Chipset, TDP 4.1W |
| Memory | Up to 8 GB DDR3 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0, 2*SATA 2.0, 1*mSATA |
| Expansion Interface | 1*PCI-E 16X, 2*Mini-PCIe (1*mSATA Supported, 1*Wifi Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7/8/10, Linux |
| I/O Interface | |
| Serial Port | 10*RS232 (COM3 RS485 optional) |
| USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1*LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2048*1536@75Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | ATX PSU |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
