1000BASE-T|100m|RJ-45 SFP|FCLF8521P2BTL
特征
  • Up to 1.25Gb/s bi-directional data links
  • Hot-pluggable SFP footprint
  • Fully metallic enclosure for low EMI
  • RoHS compliant and Lead Free
  • Low power dissipation (1.05 W typical)
  • Compact RJ-45 connector assembly
  • Access to physical layer IC via 2-wire serial bus
  • 10/100/1000 BASE-T operation in host systems with SGMII interface
  • Extended case temperature range: -40°C to 85°C
应用
  • 1.25 Gigabit Ethernet over Cat 5 cable
嵌入式主板
