EM9287是英创公司新近推出的,专门针对网络通讯、智能终端等应用的工控主板产品。EM9287可选择预装Linux-3.9.7操作系统。在Linux-3.9.7中,AD数据采集已采用新的工业IO(简称IIO)驱动程序框架,本文主要介绍应用程序如何读取相关的AD数据。此外,英创公司的另一款主流工控主板产品EM9280也升级到Linux-3.9.7,具有与EM9287完全相同的AD通道,因此本文所介绍的AD数据读取方法同样适用于EM9280。
EM9287支持2路单端模拟信号输入AIN1和AIN2,输入量程为 0V – 3.6V,信号管脚在CN1的17#和18#管脚。除了支持2路AD外,应用程序还可读取主板的CPU芯片iMX28的芯片当前温度,以了解设备的运行情况。以下是测试程序:
#include
#include
#include
#include
#include
char iiotype[16][32] = {
''in_voltage0_raw'',
'in_voltage1_raw',
'in_voltage2_raw',
'in_voltage3_raw',
'in_voltage4_raw',
'in_voltage5_raw',
'in_voltage6_raw',
'in_voltage7_raw',
'in_temp8_raw',
'in_temp9_raw',
'in_voltage10_raw',
'in_voltage11_raw',
'in_voltage12_raw',
'in_voltage13_raw',
'in_voltage14_raw',
'in_voltage15_raw' };
// return = 0: voltage value from AIN1, unit: mV
// < 0: failed
int read_AIN1(float *fvoltage)
int value, ret = 0;
char filename[80];
FILE *fp;
char buf[20];
sprintf( filename, '/sys/bus/iio/devices/iio:device0/%s', iiotype[0]);
fp = fopen(filename, 'rt' );
if( fp==NULL )
printf('open %s fail!
', filename);
*fvoltage = 0.0;
ret = -1;
return ret;
fread( buf, 1, sizeof(buf), fp );
fclose(fp);
// convert to integer
sscanf( buf, '%d', &value );
*fvoltage = 0.9 * value;
return ret;
// return = 0: voltage value from AIN2, unit: mV
// < 0: failed
int read_AIN2(float *fvoltage)
int value, ret = 0;
char filename[80];
FILE *fp;
char buf[20];
sprintf( filename, '/sys/bus/iio/devices/iio:device0/%s', iiotype[1]);
if( fp==NULL )
', filename);
*fvoltage = 0.0;
ret = -1;
return ret;
fclose(fp);
return ret;
// return = 0: temperature value from CPU, unit: K (Kalvin)
// < 0: failed
int read_CPU_temperature(float *ftemp)
int v_ch9, v_ch8, ret = 0;
char filename[80];
FILE *fp;
char buf[20];
sprintf( filename, '/sys/bus/iio/devices/iio:device0/%s', iiotype[9]);
if( fp==NULL )
', filename);
*ftemp = 0.0;
ret = -1;
return ret;
fclose(fp);
sscanf( buf, '%d', &v_ch9 );
sprintf( filename, '/sys/bus/iio/devices/iio:device0/%s', iiotype[8]);
if( fp==NULL )
', filename);
*ftemp = 0.0;
ret = -1;
return ret;
fclose(fp);
sscanf( buf, '%d', &v_ch8 );
*ftemp = ((float)(v_ch9 - v_ch8) * 1012) / 4000;
return ret;
int main(int argc, char** argv)
int ret = 0;
float fvalue;
printf('EM9280/EM9287 IIO AD test v2.0
// read AIN1
ret = read_AIN1(&fvalue);
if(ret < 0)
return ret;
printf('AIN1 = %.2f mV
', fvalue);
// read AIN2
ret = read_AIN2(&fvalue);
if(ret < 0)
return ret;
printf('AIN2 = %.2f mV
', fvalue);
// read CPU temperature
ret = read_CPU_temperature(&fvalue);
if(ret < 0)
return ret;
printf('CPU Temperature = %.1f K, (%.1f C degree)
', fvalue, (fvalue - 273));
return ret;
在控制台(console)窗口,也可通过Linux命令查看IIO驱动的原始通道:
进一步,可用cat命令读取各个通道AD转换的原始数据,EM9280、EM9287内部AD分辨率为12-bit,所以原始数据范围为:0 – 4095。开发人员可通过以下命令来快速了解设备的AD数据状况。
#cat in_voltage0_raw // 读取CH0的原始数据
#cat in_voltage1_raw // 读取CH1的原始数据
#cat in_temp8_raw // 读取CPU温度的原始数据
#cat in_temp9_raw // 读取CPU温度的原始数据
其他的原始通道涉及EM9287的触摸屏、内部供电电源等,已不在本文的介绍范围。
