orcad
三极管的Pspice模型参数
Model
模型参数
含 义
单位
默认值
备 注
AF
flicker noise exponent
1.0
噪声指数
BF
ideal maximum forward beta
100.0
最大正向放大倍数
BR
ideal maximum reverse beta
1.0
最大反向放大倍数
CJC
base-collector zero-bias p-n capacitance
farad
0.0
集电结电容
CJE
base-emitter zero-bias p-n capacitance
farad
0.0
发射结电容
CJS (CCS)
Substrate zero-bias p-n capacitance
farad
0.0
EG
bandgap voltage (barrier height)
eV
1.11
FC
forward-bias depletion capacitor coefficient
0.5
GAMMA
epitaxial region doping factor
1E-11
IKF (IK)
corner for forward-beta high-current roll-off
amp
infinite
IKR
corner for reverse-beta high-current roll-off
amp
infinite
IRB
current at which Rb falls halfway to
amp
infinite
IS
transport saturation current
amp
1E-16
饱和电流
ISC (C4)
base-collector leakage saturation current
amp
0.0
集电结漏电流
ISE (C2)
base-emitter leakage saturation current
amp
0.0
发射结漏电流
ISS
substrate p-n saturation current
amp
0.0
ITF
transit time dependency on Ic
amp
0.0
KF
flicker noise coefficient
0.0
噪声系数
MJC (MC)
base-collector p-n grading factor
0.33
MJE (ME)
base-emitter p-n grading factor
0.33
MJS (MS)
substrate p-n grading factor
0.0
NC
base-collector leakage emission coefficient
2.0
集电结漏电系数
NE
base-emitter leakage emission coefficient
1.5
发射结漏电系数
NF
forward current emission coefficient
1.0
正向电流系数
NK
high-current roll-off coefficient
0.5
NR
reverse current emission coefficient
1.0
NS
substrate p-n emission coefficient
1.0
PTF
excess phase @ 1/(2p•TF)Hz
degree
0.0
QCO
epitaxial region charge factor
coulomb
0.0
RB
zero-bias (maximum) base resistance
ohm
0.0
最大基极电阻
RBM
minimum base resistance
ohm
RB
最小基极电阻
RC
collector ohmic resistance
ohm
0.0
RCO
epitaxial region resistance
ohm
0.0
RE
emitter ohmic resistance
ohm
0.0
TF
ideal forward transit time
sec
0.0
正向传递时间
TR
ideal reverse transit time
sec
0.0
反向传递时间
TRB1
RB temperature coefficient (linear)
0C -1
0.0
RB的温度系数
TRB2
RB temperature coefficient (quadratic)
0C -2
0.0
TRC1
RC temperature coefficient (linear)
0C -1
0.0
TRC2
RC temperature coefficient (quadratic)
0C -2
0.0
TRE1
RE temperature coefficient (linear)
0C -1
0.0
TRE2
RE temperature coefficient (quadratic)
0C -2
0.0
TRM1
RBM temperature coefficient (linear)
0C -1
0.0
TRM2
RBM temperature coefficient (quadratic)
0C -2
0.0
T_ABS
absolute temperature
0C
T_MEASURED
measured temperature
0C
T_REL_GLOBAL
relative to current temperature
0C
T_REL_LOCAL
relative to AKO model temperature
0C
VAF (VA)
forward Early voltage
volt
infinite
VAR (VB)
reverse Early voltage
volt
infinite
VJC (PC)
base-collector built-in potential
volt
0.75
VJE (PE)
base-emitter built-in potential
volt
0.75
VJS (PS)
substrate p-n built-in potential
volt
0.75
VO
carrier mobility knee voltage
volt
10.0
VTF
transit time dependency on Vbc
volt
infinite
XCJC
fraction of CJC connected internally to Rb
1.0
XCJC2
1.0
XTB
forward and reverse beta temperature coefficient
0.0
正向和反向放大倍数的温度影响系数
XTF
transit time bias dependence coefficient
0.0
传递时间系数
XTI (PT)
IS temperature effect exponent
3.0 |
IS的温度影响系数 |
