使用Arduino的大型实时时钟的制作
步骤1:
使用p10 Matrix Display和DS3231 RTC时钟。
硬件:
Arduino Uno x 1
按钮(键盘)x 4
RTC模块(DS3231)
P10点矩阵显示
软件:
Arduino IDE
DMD 2库/DMD库
在此之前,您需要一个必须在Arduino IDE上安装的支持库。要下载上面提到的DMD2库
步骤2:连接
时钟
时钟
* Arduino-》 RTC模块*
A4-》 SDA
A5-》 SCL
VCC-》 5V
GND-》 GND
* Arduino-》 P10 DMD *
D8-》 SCK
D6-》 A
D7- 》 B
D11-》 R
D13-》 CLK
D9-》 OE
第3步:代码
You can find the sample code below.
//使用Arduino的Chakra Healing Harmonizer
/*访问Channel以获得更有趣的信息项目https://www.youtube.com/channel/UCks-9JSnVb22dlqt.。.*/
byte dayOfWeek=4;
byte dayOfMonth=1;#include //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include //
#include //
#include “Wendy3x5.h”
#include “Wire.h”
#define DS1307_I2C_ADDRESS 0x68int AlarmSetPin = 2;
int SnoozePin = 3;
int Alarm = 4;
int AlarmSet = 0;
int Snooze = 0;
int a,b;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
}// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
}// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock// Assumes you‘re passing in valid numbersvoid setDateDs1307(byte second, // 0-59
byte minute, // 0-59
byte hour, // 1-23
byte dayOfWeek, // 1-7
byte dayOfMonth, // 1-28/29/30/31
byte month, // 1-12
byte year) // 0-99
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(dayOfWeek));
Wire.write(decToBcd(dayOfMonth));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(00010000); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
Wire.endTransmission();
}// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
// Reset the register pointer
Wire.write(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
}//Fire up the DMD library as dmd
DMD dmd(1,1);void ScanDMD()
dmd.scanDisplayBySPI();
}void setup()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year; //initialize TimerOne’s interrupt/CPU usage used to scan and refresh the display
Timer1.initialize( 5000 ); //period in microseconds to call ScanDMD. Anything longer than 5000 (5ms) and you can see flicker.
Timer1.attachInterrupt( ScanDMD ); //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI() //clear/init the DMD pixels held in RAM
dmd.clearScreen( true ); //true is normal (all pixels off), false is negative (all pixels on)
dmd.selectFont(Wendy3x5 ); Wire.begin(); // Change these values to what you want to set your clock to.
// You probably only want to set your clock once and then remove
// the setDateDs1307 call. second = 0;
minute = 35;
hour = 11; // use 24-hour time otherwise day/date calculations will be off
dayOfWeek = 1;
dayOfMonth = 23;
month = 3;
year = 14;
//uncomment the setDateDs1307 call below to set time to intervals above. Remember if you set the time
//you need to uncomment the line below again otherwise the sketch will only stay at the time set.
//setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year); pinMode(AlarmSetPin, INPUT_PULLUP);
pinMode(SnoozePin, INPUT_PULLUP);
pinMode(Alarm, OUTPUT);
digitalWrite(Alarm, LOW);
}void drawDay()
// shows day of week
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
switch(dayOfWeek)
case 1:
dmd.drawString( 1,0, “Sun,”, 3, GRAPHICS_NORMAL );
break; case 2:
dmd.drawString( 1,0, “Mon,”, 3, GRAPHICS_NORMAL );
break; case 3:
dmd.drawString( 1,0, “Tue,”, 3, GRAPHICS_NORMAL );
break; case 4:
dmd.drawString( 1,0, “Wed,”, 3, GRAPHICS_NORMAL );
break; case 5:
dmd.drawString( 1,0, “Thu,”, 3, GRAPHICS_NORMAL );
break; case 6:
dmd.drawString( 1,0, “Fri,”, 3, GRAPHICS_NORMAL );
break; case 7:
dmd.drawString( 1,0, “Sat,”, 3, GRAPHICS_NORMAL );
break;
}void drawDate()
// shows numerical date
switch(dayOfMonth)
case 1:
dmd.drawString( 20,0, “01”, 2, GRAPHICS_NORMAL );
break;
case 2:
dmd.drawString( 20,0, “02”, 2, GRAPHICS_NORMAL );
break;
case 3:
dmd.drawString( 20,0, “03”, 2, GRAPHICS_NORMAL );
break;
case 4:
dmd.drawString( 20,0, “04”, 2, GRAPHICS_NORMAL );
break;
case 5:
dmd.drawString( 20,0, “05”, 2, GRAPHICS_NORMAL );
break;
case 6:
dmd.drawString( 20,0, “06”, 2, GRAPHICS_NORMAL );
break;
case 7:
dmd.drawString( 20,0, “07”, 2, GRAPHICS_NORMAL );
break;
case 8:
dmd.drawString( 20,0, “08”, 2, GRAPHICS_NORMAL );
break;
case 9:
dmd.drawString( 20,0, “09”, 2, GRAPHICS_NORMAL );
break;
case 10:
dmd.drawString( 20,0, “10”, 2, GRAPHICS_NORMAL );
break;
case 11:
dmd.drawString( 20,0, “11”, 2, GRAPHICS_NORMAL );
break;
case 12:
dmd.drawString( 20,0, “12”, 2, GRAPHICS_NORMAL );
break;
case 13:
dmd.drawString( 20,0, “13”, 2, GRAPHICS_NORMAL );
break;
case 14:
dmd.drawString( 20,0, “14”, 2, GRAPHICS_NORMAL );
break;
case 15:
dmd.drawString( 20,0, “15”, 2, GRAPHICS_NORMAL );
break;
case 16:
dmd.drawString( 20,0, “16”, 2, GRAPHICS_NORMAL );
break;
case 17:
dmd.drawString( 20,0, “17”, 2, GRAPHICS_NORMAL );
break;
case 18:
dmd.drawString( 20,0, “18”, 2, GRAPHICS_NORMAL );
break;
case 19:
dmd.drawString( 20,0, “19”, 2, GRAPHICS_NORMAL );
break;
case 20:
dmd.drawString( 20,0, “20”, 2, GRAPHICS_NORMAL );
break;
case 21:
dmd.drawString( 20,0, “21”, 2, GRAPHICS_NORMAL );
break;
case 22:
dmd.drawString( 20,0, “22”, 2, GRAPHICS_NORMAL );
break;
case 23:
dmd.drawString( 20,0, “23”, 2, GRAPHICS_NORMAL );
break;
case 24:
dmd.drawString( 20,0, “24”, 2, GRAPHICS_NORMAL );
break;
case 25:
dmd.drawString( 20,0, “25”, 2, GRAPHICS_NORMAL );
break;
case 26:
dmd.drawString( 20,0, “26”, 2, GRAPHICS_NORMAL );
break;
case 27:
dmd.drawString( 20,0, “27”, 2, GRAPHICS_NORMAL );
break;
case 28:
dmd.drawString( 20,0, “28”, 2, GRAPHICS_NORMAL );
break;
case 29:
dmd.drawString( 20,0, “29”, 2, GRAPHICS_NORMAL );
break;
case 30:
dmd.drawString( 20,0, “30”, 2, GRAPHICS_NORMAL );
break;
case 31:
dmd.drawString( 20,0, “31”, 2, GRAPHICS_NORMAL );
break;
}void drawHour()
// draws the hour hand
if (hour》12) //Remove this if command for 24 hour time
hour=hour-12; // This is a 12 hour Clock
switch(hour)
case 1:
dmd.drawString( 0,0, “01”, 2, GRAPHICS_NORMAL );
break;
case 2:
dmd.drawString( 0,0, “02”, 2, GRAPHICS_NORMAL );
break;
case 3:
dmd.drawString( 0,0, “03”, 2, GRAPHICS_NORMAL );
break;
case 4:
dmd.drawString( 0,0, “04”, 2, GRAPHICS_NORMAL );
break;
case 5:
dmd.drawString( 0,0, “05”, 2, GRAPHICS_NORMAL );
break;
case 6:
dmd.drawString( 0,0, “06”, 2, GRAPHICS_NORMAL );
break;
case 7:
dmd.drawString( 0,0, “07”, 2, GRAPHICS_NORMAL );
break;
case 8:
dmd.drawString( 0,0, “08”, 2, GRAPHICS_NORMAL );
break;
case 9:
dmd.drawString( 0,0, “09”, 2, GRAPHICS_NORMAL );
break;
case 10:
dmd.drawString( 0,0, “10”, 2, GRAPHICS_NORMAL );
break;
case 11:
dmd.drawString( 0,0, “11”, 2, GRAPHICS_NORMAL );
break;
case 12:
dmd.drawString( 0,0, “12”, 2, GRAPHICS_NORMAL );
break;
case 13:
dmd.drawString( 0,0, “13”, 2, GRAPHICS_NORMAL );
break;
case 14:
dmd.drawString( 0,0, “14”, 2, GRAPHICS_NORMAL );
break;
case 15:
dmd.drawString( 0,0, “15”, 2, GRAPHICS_NORMAL );
break;
case 16:
dmd.drawString( 0,0, “16”, 2, GRAPHICS_NORMAL );
break;
case 17:
dmd.drawString( 0,0, “17”, 2, GRAPHICS_NORMAL );
break;
case 18:
dmd.drawString( 0,0, “18”, 2, GRAPHICS_NORMAL );
break;
case 19:
dmd.drawString( 0,0, “19”, 2, GRAPHICS_NORMAL );
break;
case 20:
dmd.drawString( 0,0, “20”, 2, GRAPHICS_NORMAL );
break;
case 21:
dmd.drawString( 0,0, “21”, 2, GRAPHICS_NORMAL );
break;
case 22:
dmd.drawString( 0,0, “22”, 2, GRAPHICS_NORMAL );
break;
case 23:
dmd.drawString( 0,0, “23”, 2, GRAPHICS_NORMAL );
break;
case 24:
dmd.drawString( 0,0, “24”, 2, GRAPHICS_NORMAL );
break;
}void drawMinute()
switch(minute)
case 0:
dmd.drawString( 12,0, “00”, 2, GRAPHICS_NORMAL );
break;
case 1:
dmd.drawString( 12,0, “01”, 2, GRAPHICS_NORMAL );
break;
case 2:
dmd.drawString( 12,0, “02”, 2, GRAPHICS_NORMAL );
break;
case 3:
dmd.drawString( 12,0, “03”, 2, GRAPHICS_NORMAL );
break;
case 4:
dmd.drawString( 12,0, “04”, 2, GRAPHICS_NORMAL );
break;
case 5:
dmd.drawString( 12,0, “05”, 2, GRAPHICS_NORMAL );
break;
case 6:
dmd.drawString( 12,0, “06”, 2, GRAPHICS_NORMAL );
break;
case 7:
dmd.drawString( 12,0, “07”, 2, GRAPHICS_NORMAL );
break;
case 8:
dmd.drawString( 12,0, “08”, 2, GRAPHICS_NORMAL );
break;
case 9:
dmd.drawString( 12,0, “09”, 2, GRAPHICS_NORMAL );
break;
case 10:
dmd.drawString( 12,0, “10”, 2, GRAPHICS_NORMAL );
break;
case 11:
dmd.drawString( 12,0, “11”, 2, GRAPHICS_NORMAL );
break;
case 12:
dmd.drawString( 12,0, “12”, 2, GRAPHICS_NORMAL );
break;
case 13:
dmd.drawString( 12,0, “13”, 2, GRAPHICS_NORMAL );
break;
case 14:
dmd.drawString( 12,0, “14”, 2, GRAPHICS_NORMAL );
break;
case 15:
dmd.drawString( 12,0, “15”, 2, GRAPHICS_NORMAL );
break;
case 16:
dmd.drawString( 12,0, “16”, 2, GRAPHICS_NORMAL );
break;
case 17:
dmd.drawString( 12,0, “17”, 2, GRAPHICS_NORMAL );
break;
case 18:
dmd.drawString( 12,0, “18”, 2, GRAPHICS_NORMAL );
break;
case 19:
dmd.drawString( 12,0, “19”, 2, GRAPHICS_NORMAL );
break;
case 20:
dmd.drawString( 12,0, “20”, 2, GRAPHICS_NORMAL );
break;
case 21:
dmd.drawString( 12,0, “21”, 2, GRAPHICS_NORMAL );
break;
case 22:
dmd.drawString( 12,0, “22”, 2, GRAPHICS_NORMAL );
break;
case 23:
dmd.drawString( 12,0, “23”, 2, GRAPHICS_NORMAL );
break;
case 24:
dmd.drawString( 12,0, “24”, 2, GRAPHICS_NORMAL );
break;
case 25:
dmd.drawString( 12,0, “25”, 2, GRAPHICS_NORMAL );
break;
case 26:
dmd.drawString( 12,0, “26”, 2, GRAPHICS_NORMAL );
break;
case 27:
dmd.drawString( 12,0, “27”, 2, GRAPHICS_NORMAL );
break;
case 28:
dmd.drawString( 12,0, “28”, 2, GRAPHICS_NORMAL );
break;
case 29:
dmd.drawString( 12,0, “29”, 2, GRAPHICS_NORMAL );
break;
case 30:
dmd.drawString( 12,0, “30”, 2, GRAPHICS_NORMAL );
break;
case 31:
dmd.drawString( 12,0, “31”, 2, GRAPHICS_NORMAL );
break;
case 32:
dmd.drawString( 12,0, “32”, 2, GRAPHICS_NORMAL );
break;
case 33:
dmd.drawString( 12,0, “33”, 2, GRAPHICS_NORMAL );
break;
case 34:
dmd.drawString( 12,0, “34”, 2, GRAPHICS_NORMAL );
break;
case 35:
dmd.drawString( 12,0, “35”, 2, GRAPHICS_NORMAL );
break;
case 36:
dmd.drawString( 12,0, “36”, 2, GRAPHICS_NORMAL );
break;
case 37:
dmd.drawString( 12,0, “37”, 2, GRAPHICS_NORMAL );
break;
case 38:
dmd.drawString( 12,0, “38”, 2, GRAPHICS_NORMAL );
break;
case 39:
dmd.drawString( 12,0, “39”, 2, GRAPHICS_NORMAL );
break;
case 40:
dmd.drawString( 12,0, “40”, 2, GRAPHICS_NORMAL );
break;
case 41:
dmd.drawString( 12,0, “41”, 2, GRAPHICS_NORMAL );
break;
case 42:
dmd.drawString( 12,0, “42”, 2, GRAPHICS_NORMAL );
break;
case 43:
dmd.drawString( 12,0, “43”, 2, GRAPHICS_NORMAL );
break;
case 44:
dmd.drawString( 12,0, “44”, 2, GRAPHICS_NORMAL );
break;
case 45:
dmd.drawString( 12,0, “45”, 2, GRAPHICS_NORMAL );
break;
case 46:
dmd.drawString( 12,0, “46”, 2, GRAPHICS_NORMAL );
break;
case 47:
dmd.drawString( 12,0, “47”, 2, GRAPHICS_NORMAL );
break;
case 48:
dmd.drawString( 12,0, “48”, 2, GRAPHICS_NORMAL );
break;
case 49:
dmd.drawString( 12,0, “49”, 2, GRAPHICS_NORMAL );
break;
case 50:
dmd.drawString( 12,0, “50”, 2, GRAPHICS_NORMAL );
break;
case 51:
dmd.drawString( 12,0, “51”, 2, GRAPHICS_NORMAL );
break;
case 52:
dmd.drawString( 12,0, “52”, 2, GRAPHICS_NORMAL );
break;
case 53:
dmd.drawString( 12,0, “53”, 2, GRAPHICS_NORMAL );
break;
case 54:
dmd.drawString( 12,0, “54”, 2, GRAPHICS_NORMAL );
break;
case 55:
dmd.drawString( 12,0, “55”, 2, GRAPHICS_NORMAL );
break;
case 56:
dmd.drawString( 12,0, “56”, 2, GRAPHICS_NORMAL );
break;
case 57:
dmd.drawString( 12,0, “57”, 2, GRAPHICS_NORMAL );
break;
case 58:
dmd.drawString( 12,0, “58”, 2, GRAPHICS_NORMAL );
break;
case 59:
dmd.drawString( 12,0, “59”, 2, GRAPHICS_NORMAL );
break;
}void drawSec()
switch(second)
case 0:
dmd.drawString( 24,0, “00”, 2, GRAPHICS_NORMAL );
break;
case 1:
dmd.drawString( 24,0, “01”, 2, GRAPHICS_NORMAL );
break;
case 2:
dmd.drawString( 24,0, “02”, 2, GRAPHICS_NORMAL );
break;
case 3:
dmd.drawString( 24,0, “03”, 2, GRAPHICS_NORMAL );
break;
case 4:
dmd.drawString( 24,0, “04”, 2, GRAPHICS_NORMAL );
break;
case 5:
dmd.drawString( 24,0, “05”, 2, GRAPHICS_NORMAL );
break;
case 6:
dmd.drawString( 24,0, “06”, 2, GRAPHICS_NORMAL );
break;
case 7:
dmd.drawString( 24,0, “07”, 2, GRAPHICS_NORMAL );
break;
case 8:
dmd.drawString( 24,0, “08”, 2, GRAPHICS_NORMAL );
break;
case 9:
dmd.drawString( 24,0, “09”, 2, GRAPHICS_NORMAL );
break;
case 10:
dmd.drawString( 24,0, “10”, 2, GRAPHICS_NORMAL );
break;
case 11:
dmd.drawString( 24,0, “11”, 2, GRAPHICS_NORMAL );
break;
case 12:
dmd.drawString( 24,0, “12”, 2, GRAPHICS_NORMAL );
break;
case 13:
dmd.drawString( 24,0, “13”, 2, GRAPHICS_NORMAL );
break;
case 14:
dmd.drawString( 24,0, “14”, 2, GRAPHICS_NORMAL );
break;
case 15:
dmd.drawString( 24,0, “15”, 2, GRAPHICS_NORMAL );
break;
case 16:
dmd.drawString( 24,0, “16”, 2, GRAPHICS_NORMAL );
break;
case 17:
dmd.drawString( 24,0, “17”, 2, GRAPHICS_NORMAL );
break;
case 18:
dmd.drawString( 24,0, “18”, 2, GRAPHICS_NORMAL );
break;
case 19:
dmd.drawString( 24,0, “19”, 2, GRAPHICS_NORMAL );
break;
case 20:
dmd.drawString( 24,0, “20”, 2, GRAPHICS_NORMAL );
break;
case 21:
dmd.drawString( 24,0, “21”, 2, GRAPHICS_NORMAL );
break;
case 22:
dmd.drawString( 24,0, “22”, 2, GRAPHICS_NORMAL );
break;
case 23:
dmd.drawString( 24,0, “23”, 2, GRAPHICS_NORMAL );
break;
case 24:
dmd.drawString( 24,0, “24”, 2, GRAPHICS_NORMAL );
break;
case 25:
dmd.drawString( 24,0, “25”, 2, GRAPHICS_NORMAL );
break;
case 26:
dmd.drawString( 24,0, “26”, 2, GRAPHICS_NORMAL );
break;
case 27:
dmd.drawString( 24,0, “27”, 2, GRAPHICS_NORMAL );
break;
case 28:
dmd.drawString( 24,0, “28”, 2, GRAPHICS_NORMAL );
break;
case 29:
dmd.drawString( 24,0, “29”, 2, GRAPHICS_NORMAL );
break;
case 30:
dmd.drawString( 24,0, “30”, 2, GRAPHICS_NORMAL );
break;
case 31:
dmd.drawString( 24,0, “31”, 2, GRAPHICS_NORMAL );
break;
case 32:
dmd.drawString( 24,0, “32”, 2, GRAPHICS_NORMAL );
break;
case 33:
dmd.drawString( 24,0, “33”, 2, GRAPHICS_NORMAL );
break;
case 34:
dmd.drawString( 24,0, “34”, 2, GRAPHICS_NORMAL );
break;
case 35:
dmd.drawString( 24,0, “35”, 2, GRAPHICS_NORMAL );
break;
case 36:
dmd.drawString( 24,0, “36”, 2, GRAPHICS_NORMAL );
break;
case 37:
dmd.drawString( 24,0, “37”, 2, GRAPHICS_NORMAL );
break;
case 38:
dmd.drawString( 24,0, “38”, 2, GRAPHICS_NORMAL );
break;
case 39:
dmd.drawString( 24,0, “39”, 2, GRAPHICS_NORMAL );
break;
case 40:
dmd.drawString( 24,0, “40”, 2, GRAPHICS_NORMAL );
break;
case 41:
dmd.drawString( 24,0, “41”, 2, GRAPHICS_NORMAL );
break;
case 42:
dmd.drawString( 24,0, “42”, 2, GRAPHICS_NORMAL );
break;
case 43:
dmd.drawString( 24,0, “43”, 2, GRAPHICS_NORMAL );
break;
case 44:
dmd.drawString( 24,0, “44”, 2, GRAPHICS_NORMAL );
break;
case 45:
dmd.drawString( 24,0, “45”, 2, GRAPHICS_NORMAL );
break;
case 46:
dmd.drawString( 24,0, “46”, 2, GRAPHICS_NORMAL );
break;
case 47:
dmd.drawString( 24,0, “47”, 2, GRAPHICS_NORMAL );
break;
case 48:
dmd.drawString( 24,0, “48”, 2, GRAPHICS_NORMAL );
break;
case 49:
dmd.drawString( 24,0, “49”, 2, GRAPHICS_NORMAL );
break;
case 50:
dmd.drawString( 24,0, “50”, 2, GRAPHICS_NORMAL );
break;
case 51:
dmd.drawString( 24,0, “51”, 2, GRAPHICS_NORMAL );
break;
case 52:
dmd.drawString( 24,0, “52”, 2, GRAPHICS_NORMAL );
break;
case 53:
dmd.drawString( 24,0, “53”, 2, GRAPHICS_NORMAL );
break;
case 54:
dmd.drawString( 24,0, “54”, 2, GRAPHICS_NORMAL );
break;
case 55:
dmd.drawString( 24,0, “55”, 2, GRAPHICS_NORMAL );
break;
case 56:
dmd.drawString( 24,0, “56”, 2, GRAPHICS_NORMAL );
break;
case 57:
dmd.drawString( 24,0, “57”, 2, GRAPHICS_NORMAL );
break;
case 58:
dmd.drawString( 24,0, “58”, 2, GRAPHICS_NORMAL );
break;
case 59:
dmd.drawString( 24,0, “59”, 2, GRAPHICS_NORMAL );
break;
}void drawCol1()
dmd.drawString( 8,0, “:”, 1, GRAPHICS_NORMAL );
}void drawCol2()
dmd.drawString( 20,0, “:”, 1, GRAPHICS_NORMAL );
}void runClock()
// drawDay();
// drawDate();
drawHour();
drawCol1();
drawMinute();
drawCol2();
drawSec();
// CheckAlarm();}/*void AlarmSequence() {
drawDay();
drawDate();
drawHour();
drawCol();
drawMinute();
digitalWrite(Alarm, HIGH);
delay(1000);
delay(1000);
/*void CheckAlarm() {
AlarmSet = digitalRead(AlarmSetPin);
Snooze = digitalRead(SnoozePin);
getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);*/
/* Only Trigger Alarm If it is a day listed below. This can be changed by changing the numbers to any of the following:
1 = Sunday
2 = Monday
3 = Tuesday
4 = Wednesday
5 = Thursday
6 = Friday
7 = Saturday
/* if(dayOfWeek == 2 || dayOfWeek == 3 || dayOfWeek == 4 || dayOfWeek == 5 ||dayOfWeek == 6) { //This is days ALLOWED to ring alarm
if(hour == 18 && minute == 05 ) { //Set Time Here (In 24 hour Time)
if(AlarmSet == LOW) { //If alarm pin is on
while(Snooze == HIGH)
AlarmSequence();
void loop()
runClock();
第4步:功能
DMD
32 x 16个高亮度红色LED(总共512个LED),间距为10mm
支持5V操作
可以在12米远的地方看到
坚固的塑料框架
板载控制器IC
Arduino兼容库,图形功能
RTC
计算秒,分钟,小时和年份
Accura cy:0ºC至+40ºC时为+ 2ppm至-2ppm,-40ºC至+85ºC时为+ 3.5ppm至-3.5ppm
数字温度传感器,精度为±3ºC
两次日警报
可编程方波输出
寄存器老化调整400Khz I2C接口
低功耗
自动断电电池开关电路
CR2032备用电池,使用寿命为两到三年
步骤5:该项目的工作:简单时钟
第6步:该项目的工作:按设置进行计时
