蓝牙低功耗存在检测器的制作教程
步骤1:零件
我正在使用ESP32 Feather,但其他任何功能都可以使用
1 5v继电器
1 TIP31C转换器
1个BLE服务器设备(任何信标设备)
由于ESP32的3V3数字输出电压和电流不足,因此TIP31C用于控制继电器的方式
继电器控制120V灯光,腕带可检测到人的存在。
步骤2:电路
蓝牙
此很简单,ESP32的引脚号33到达晶体管的基极,因此我们可以添加5V VCC信号,并通过3V3电压输出控制更大的电压,然后,通过继电器我们可以控制120V
步骤3:代码
#include “BLEDevice.h”
int Lampara = 33;
int Contador = 0; static BLEAddress *pServerAddress;
BLEScan* pBLEScan;
BLEClient* pClient;
bool deviceFound = false;
bool Encendida = false;
bool BotonOff = false; String knownAddresses[] = { “your:device:mac:address”};
unsigned long entry; static void notifyCallback(
BLERemoteCharacteristic* pBLERemoteCharacteristic,
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.print(“Notify callback for characteristic ”);
Serial.print(pBLERemoteCharacteristic-》getUUID().toString().c_str());
Serial.print(“ of data length ”);
Serial.println(length);
} class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
void onResult(BLEAdvertisedDevice Device){
//Serial.print(“BLE Advertised Device found: ”);
//Serial.println(Device.toString().c_str());
pServerAddress = new BLEAddress(Device.getAddress());
bool known = false;
bool Master = false;
for (int i = 0; i 《 (sizeof(knownAddresses) / sizeof(knownAddresses[0])); i++) {
if (strcmp(pServerAddress-》toString().c_str(), knownAddresses[i].c_str()) == 0)
known = true;
if (known) {
Serial.print(“Device found: ”);
Serial.println(Device.getRSSI());
if (Device.getRSSI() 》 -85) {
deviceFound = true;
else {
Device.getScan()-》stop();
delay(100);
}; void setup() {
Serial.begin(115200);
pinMode(Lampara,OUTPUT);
digitalWrite(Lampara,LOW);
BLEDevice::init(“”);
pClient = BLEDevice::createClient();
pBLEScan = BLEDevice::getScan();
pBLEScan-》setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan-》setActiveScan(true);
Serial.println(“Done”);
} void Bluetooth() {
Serial.println();
Serial.println(“BLE Scan restarted.。..。”);
BLEScanResults scanResults = pBLEScan-》start(5);
if (deviceFound) {
Serial.println(“Encender Lamara”);
Encendida = true;
digitalWrite(Lampara,HIGH);
Contador = 0;
delay(10000);
else{
delay(1000);
} void loop() {
Bluetooth();
步骤4:用于灯光控制的PCB
我在原型PCB上制作了这个电路,以使事情变得更干净。
第5步:完成
然后您完成了!
您可以使用此代码打开门,或控制其他事情
责任编辑:wv
