怎样将Arduino数据直接存储到MySQL
步骤1:设置Arduino
MySQL
刻录以下内容
void setup()
Serial.begin(9600);
void loop()
int i=0,j=0;
i=analogRead(A0);
j=analogRead(A1);
Serial.print(i);
Serial.print(“,”);
Serial.println(i);
步骤2:设置启动MySQL
MySQL
为MySQL安装Wamp服务器并将其配置为存储数据
运行wamp服务器
打开MySQL控制台
选择数据库
然后为您的数据创建表
create table data(sno int(4) primary key auto_increment,LDR int(4),TEMP int(4));
使用desc your_table_name显示表详细信息
desc data;
这就是数据库的全部内容,现在我们可以进行处理了……
第3步:设置处理IDE
MySQL
下载并安装Processing IDE 2.2.1
将上述给定的ZIP压缩到MyDocuments/Processing/Libraries中
现在打开正在处理的IDE和检查库是否已正确安装(如上图所示)
然后将以下代码复制并进行处理,并自行命名
ARDUINO TO MYSQL THROUGH PROCESSING
Read Serial messages from Arduino then write it in MySQL.
Author : J.V.JohnsonSelva September 2016
import de.bezier.data.sql.*; //import the MySQL library
import processing.serial.*; //import the Serial library
MySQL msql; //Create MySQL Object
String[] a;
int end = 10; // the number 10 is ASCII for linefeed (end of serial.println), later we will look for this to break up individual messages
String serial; // declare a new string called ‘serial’ 。 A string is a sequence of characters (data type know as “char”)
Serial port; // The serial port, this is a new instance of the Serial class (an Object)
void setup() {
String user = “root”;
String pass = “”;
String database = “iot_database”;
msql = new MySQL( this, “localhost”, database, user, pass );
port = new Serial(this, Serial.list()[0], 9600); // initializing the object by assigning a port and baud rate (must match that of Arduino)
port.clear(); // function from serial library that throws out the first reading, in case we started reading in the middle of a string from Arduino
serial = port.readStringUntil(end); // function that reads the string from serial port until a println and then assigns string to our string variable (called ‘serial’)
serial = null; // initially, the string will be null (empty)
void draw()
while (port.available() 》 0)
//as long as there is data coming from serial port, read it and store it
if (serial != null)
//if the string is not empty, print the following
//Note: the split function used below is not necessary if sending only a single variable. However, it is useful for parsing (separating) messages when
//reading from multiple inputs in Arduino. Below is example code for an Arduino sketch
a = split(serial, ‘,’); //a new array (called ‘a’) that stores values into separate cells (separated by commas specified in your Arduino program)
println(a[0]); //print LDR value
println(a[1]); //print LM35 value
function();
void function()
if ( msql.connect() )
msql.query( “insert into data(LDR,Temp)values(”+a[0]+“,”+a[1]+“)” );
else
// connection failed !
msql.close(); //Must close MySQL connection after Execution
第4步:执行程序。
MySQL
通过单击“运行”按钮运行程序,请关闭弹出窗口。关闭窗口将停止执行,并在下面的查询中查看在MySQL中存储数据。..
select * from data;
查看数据插入器的数量可以使用下面的查询。
select count(*) from data;
责任编辑:wv
