适用于摇头摄像机 智能门铃 WIFI直联联网更简单
可ODM定制硬件及软件 APP P2P平台对接
| Model | HFS1080PDBL |
| CPU | Ti davinci SOC |
| RAM | 1Gb Ram+1Gb Rom |
| Operation system | Standard linux 2.6.32 kernel |
| Analogy Vin | 1CH AHD/CVBS PAL/ NTSC 1Vpp@75Ω |
| Digital Vin | 1/4CH 1080P/VGA IP Video orYUV8bit BT656 |
| Compression format | H.264/MPEG4/MJPEG |
| Maximum frame rate | 1920*1080P25FPS |
| Analogy Vout | PAL720*576/ NTSC720*480 |
| Analogy HD Vout | YPbPr 1080I50 |
| Digital Vout | RBG565 LCD 800*480 or YUV16bit BT1120 output |
| MIC in | Mono 70mV Min |
| Audio Codec | G.711 or ACC |
| Audio Out | Mono 200mV@600Ω |
| Cable LAN | 802.3/ RJ45 |
| Wireless LAN | WIFI 802.11b/g/n or 3G/LTE |
| Network protocol | HTTP、TCP、UDP、RTSP、RTP、RTCP、P2P |
| Recording | SD card recording(max32G), MP4 format |
| App | Support iPhone, Android ETC. |
| Hardware Interface | 8bitYUVor12bitRaw*1,MIC*1,YPbPr or Cvbs out*1,RGB565LCD*1,Aout*1, |
| ETH*1,LED*2,WIFI*1,I2C*1,Debug*1, UART*1,USB2.0*1, Reset Pin*1, | |
| IRin*1, ICR*1,ADCin*3,SD*1,GIO*36max,Keyscan16*16max | |
| Power Supply | USB Vin5V260mA / DCin6-15V Max |
| power dissipation | <1.5W |
| Operating temp / humidity | -10 ℃ ~ +50 ℃ / 10% -90% non-condensing |
| Size | 38mm *44mm *10 mm |
TI芯片以其稳定的性能,适合做大项目类的工程,普遍应用在工业级别的产品上,例如:医疗的口腔窥镜,无线3G无人机的图像传输,车载列车巴士的广告机系统,偏远边疆的安防哨所3G视频摄像机,监狱看守所的网络高清视频摄像机等场合。
海富思科技以设计方案为主,有品质有个性化智能化提升竞争力的高科技产品!
