适合使用场合及产品:智能对讲门禁系统,智能可视门铃系统,机器人摄像,无人机图像成像传输,医疗用成像摄像,车载记录成像,安防网络摄像机,3G摄像机,WIFI摄像机,USB摄像头。
| Model | HFS480PDBL |
| CPU | ARM926EJ-S SOC |
| RAM | 128Mb RAM+128Mb ROM |
| Operation System | Standard Linux 2.6.32 kernel |
| Analogy Vin | 1CH CVBS PAL/NTSC 1Vpp@75Ω |
| Digital Vin | 1CH VGA IP Video orYUV8Bits BT656 |
| Compression format | H.264/MPEG4/MJPEG |
| Maximum frame rate | 720P15FPS / VGA30FPS |
| Analogy Vout | PAL720*576 / NTSC720*480 |
| Digital Vout | RBG565 LCD 800*480 |
| MIC in | Mono 70mV Min |
| Audio Codec | G.711 or ACC |
| Audio Out | Mono 200mV@600Ω |
| Cable LAN | 802.3 /RJ45 |
| Wireless | WIFI 802.11b/g/n |
| Network protocol | HTTP, TCP, UDP, RTSP, RTP, RTCP, P2P |
| Recording | SD card recording(max64G), MP4 format |
| App | Support iPhone and Android |
| Hardware Interface | Vin*1 or 8bit Bt656*1, MIC*1, Vout*1 or RGB565LCD*1, Aout*1, ETH*1, |
| WIFI*1, LED*2, I2C*1, Debug*1, UART*1, USB2.0*1, Reset Pin*1, | |
| IRin*1, ICR*1,ADCin*1,SD*1,GIO*36max, Keyscan16*16 max | |
| Power Supply | USB Vin 5V 200mA / DCin 5-15V Max |
| Power dissipation | <1.2W |
| Operating temp / humidity | -10 ℃ ~ +50 ℃ / 10% -90% non-condensing |
| Size | 38mm *44mm *10 mm |
