FPGA/ASIC技术
ADC0809 VHDL控制程序
--文件名:ADC0809.vhd
--功能:基于VHDL语言,实现对ADC0809简单控制
--说明:ADC0809没有内部时钟,需外接10KHz~1290Hz的时钟信号,这里由FPGA的系
--统时钟(50MHz)经256分频得到clk1(195KHz)作为ADC0809转换工作时钟。
--最后修改日期:2004.3.20
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity ADC0809 is
port ( d : in std_logic_vector(7 downto 0); --ADC0809输出的采样数据
clk,eoc : in std_logic; --clk为系统时钟,eoc为ADC0809转换结束信号
clk1,start, ale,en: out std_logic; --ADC0809控制信号
abc_in :in std_logic_vector(2 downto 0); --模拟选通信号
abc_out :out std_logic_vector(2 downto 0); --ADC0809模拟信号选通信号
q : out std_logic_vector(7 downto 0)); --送至8个并排数码管信号
end ADC0809;
architecture behav of ADC0809 is
type states is ( st0,st1, st2, st3, st4,st5,st6); --定义各状态的子类型
signal current_state, next_state:states:=st0;
signal regl :std_logic_vector(7 downto 0); --中间数据寄存信号
signal qq:std_logic_vector(7 downto 0);
begin
com:process(current_state,eoc) --规定各种状态的转换方式
begin
case current_state is
when st0=>next_state<=st1;ale<='0';start<='0';en<='0';
when st1=>next_state<=st2;ale<='1';start<='0';en<='0';
when st2=>next_state<=st3;ale<='0';start<='1';en<='0';
when st3=> ale<='0';start<='0';en<='0';
if eoc='1' then next_state<=st3; --检测EOC的下降沿
else next_state<=st4;
end if;
when st4=> ale<='0';start<='0';en<='0';
if eoc='0' then next_state<=st4; --检测EOC的上升沿
else next_state<=st5;
end if;
when st5=>next_state<=st6;ale<='0';start<='0';en<='1';
when st6=>next_state<=st0;ale<='0';start<='0';en<='1';regl<=d;
when others=> next_state<=st0;ale<='0';start<='0';en<='0';
end case;
end process;
clock:process(clk) --对系统时钟进行分频,得到ADC0809转换工作时钟
begin
if clk'event and clk='1' then qq<=qq+1; --在clk1的上升沿,转换至下一状态
if QQ="01111111" THEN clk1<='1'; current_state <=next_state;
elsif qq<="01111111" then clk1<='0';
end if;
end if;
end process;
q<=regl; abc_out<=abc_in;
end behav;
