电视机专业英语
电视机
54人已加入
电视机专业英语
prescale means scale the signal before processing
sound if mixer      sif mean  sound if
AVC  auto volume  correction
A/D converter
The high filter formed by the coupling capactitors
deviation  go another way
robust means full of energy
evaluation  / estimate
manual   /work by hand
equalizing /to give help to reach the same level
distribute  /hand out separately
annoy /make sb grieve
boost / give the help to do sth advance
oscillation  /quiver librate
versus  /relate to
beeper /the intrument which can produce sound
equalizer / sb fixer which can give sth to reach the same level
exploit / get new progress by hard work
synchronous / happen at the same time
NC / not connected
LV / leave vacant
MTS / multimedia channel television sound
induction / influence
suppress  / only give the signal very small space in order to make some frequently not pass
the line
symmetrical / the same things which show the two same sides
SAP / sound  audio  program
demodulation /   get the useful signal from the carrier
amplitude /  the strength of a signal
abligatory / have to
MTS / multi channel Television sound
alignment / together by the same aim
cvbs / composite video base signal
TMOD / Timer / counter Mode Register
ISP / In-system programmable
duplex / double
nonvolate / lost difficultly
impendance /
Idle / unuse
skip /jump
SFR / special function registor
demystified  / 使非神秘化
patent  //专利
trademark // 商标
omission  //冗长
scalar //缩放控制器
digital STB // 数字机顶盒
VBI vertical blank interval
CC closed caption
TS transport stream //传输码流
demultiplexer  //解复用
subtitle //子标题
vbi   vertical blanking interval  //场消影间隙
In the interval of vertical blanking ,the cc,tt,vps can be transmited.
VPS //video program system
VPT //video program teletext
PDC //program deliver control
WSS //wide screen status  //宽屏幕标志
WST  //wide screen teletext //宽屏幕图文
ECM //资格控制信息
EMM //资格管理信息
EMI  // electromagnetism interfere
mono //the signal path of audio
  • 相关推荐
  • 热点推荐
