常用三极管
IC应用电路图
512人已加入
常用三极管
型号(规格)
M/Pol
电压VCEO(V)
电流 IC(A)
功率 PC(W)
9011
SI-NPN
30
30mA
400mW
9012
SI-PNP
625mW
9013
SI-NPN
625mW
9014
SI-NPN
45
0.1
450mW
9015
SI-PNP
45
0.1
450mW
9016
SI-NPN
25mA
400mW
9018
SI-NPN
15
50mA
400mA
8050
SI-NPN
25
1.5
1
8550
SI-PNP
25
1.5
1
2N5551
SI-NPN
160
0.6
625mW
2N5401
SI-PNP
160
0.6
625mW
2SC1815
SI-NPN
60
0.15
0.4
2SC1959
SI-NPN
35
0.5
0.5
2SA928
SI-PNP
2SC945
SI-NPN
50
0.1
250MHz
2SA940
SI-PNP
150
1.5
25
2N3904
SI-PNP
60
0.2
2N3905
SI-PNP
40
0.2
2N3906
SI-PNP
40
0.2
A42
SI-NPN
35
0.5
0.4
A92
SI-PNP
2SC1623L6
SI-NPN
50
0.1
300MHz
2SC3356R25
SI-NPN
0.2
TIP122
SI-NPN
100
5
65
TIP127
SI-PNP
100
5
65
TIP41B
SI-NPN
80
6
65
TIP41C
SI-NPN
100
6
65
TIP42C
SI-PNP
100
6
65
BU406
SI-NPN
400
7
60
BU508A
SI-NPN
1500
7.5
75
2N3055
SI-NPN
100
15
117
MJE13003
SI-NPN
400
1.5
MJE13005
SI-NPN
400
4
75
MJE13007
SI-NPN
400
8
80
MJE13009
SI-NPN
400
12
100
2SB772
SI-PNP
40
3
10
2SD882
SI-NPN
40
3
10
2SB562
SI-PNP
25
1
0.9
2SA1013
SI-PNP
160
1
0.9
2SA940
SI-PNP
150
1.5
25
2SB647
SI-PNP
120
1
0.9
2SD667
SI-NPN
120
1
0.9
2SC1213
SI-NPN
35
0.5
0.4
2SC5609
SI-NPN
2SD965
SI-NPN
40
5
0.75
2SA1015GR
SI-PNP
50
0.15
