产品名称:USB蓝牙模块
产品属性
Specification:
Bluetooth Standard |
Bluetooth 3.0 + EDR compliant |
Solution |
BCM Chipset: 2070 |
Host Interface |
USB 1.1,2.0,2.1 Compatibility |
RF Specification |
Frequency band |
2.4 GHz |
Spectrum |
FHSS |
Modulation |
GFSK,π/4 DQPSK,8DPSK |
Antenna |
PCB antenna |
Sensitivity |
-85dBm typical |
Power |
Class2, Max 6dBm |
Topology |
Piconet / Scatter net |
Data Rate |
Max 3M bps |
Operating Distance |
10 meters |
LED Indication |
Power on, Standby |
OS |
Android(TQ210) |
Power Supply |
5V USB power |
Support Profile |
Serial Port / Object Push |
File Transfer |
LAN Access |
Personal Area Network |
Audio Geteway / Heatset HID / Keyboard,Mouse |
HCRP(Printer Cable Replacement) |
PIM Synchronization Profile |
Advanced Audio Distribution Profile(A2DP) |
Audio Video Remote Control |
Profile(AVRCP) |
Current Consumption |
20mA Active Model |
Dimension |
9.8 mm x 20 mm x 2.3 mm(PCBA) |
Electrical Characteristics:
Electrical Characteristics |
Min |
Typ |
Max |
Unit |
TX mode current |
40 |
mA |
RX mode current |
15 |
mA |
Standby mode current |
1.8 |
mA |
RF/Frequency Range |
2.402 |
2.480 |
GHZ |
RF/ Transmitter power |
-3 |
0 |
4 |
dBm |
RF/Initial carrier |
-75 |
75 |
KHZ |
RF/Single slot sensitivity BER |
80 |
dbm |
10 meter distance 0 degreetransmission speeds |
150 |
KB/S |
10 meter distance 90 degree transmission speeds |
170 |
KB/S |
10 meter distance 180 degree transmission speeds |
180 |
KB/S |
Operating Temperature |
-10 |
60 |
Storage Temperature |
-20 |
80 |
Operating humidity |
75 |
Storage humidity |
85 |
适用的开发平台:
| 开发平台 | Linux | Android |
| TQ210v3平台 | OK | |
| TQ210v4平台 | OK | |
| TQ210v6平台 | OK | |
| E8卡片电脑 | OK | |
| TQ335XB平台 | OK | |
| TQ335XC平台 | OK | |
| E9_v2卡片电脑 | OK | |
| E9_v3卡片电脑 | OK | |
| TQi.MX6Q平台 | OK |
