NPO贴片电容容量范围对照表
电子常识
2685人已加入
NPO贴片电容简述
NPO(COG)贴片电容属于Class 1温度补偿型电容。它的容量稳定,几乎不随温度、电压、时间的变化而变化。尤其适用于高频电子电路。
NPO(COG)贴片电容特性
具有最高的电容量稳定性,在-55℃~125℃工作温度范围内,温度特性为:0±30ppm/℃(COG)、0±60ppm/℃(COH)。
层叠独石结构,具有高可靠性。
优良的焊接性和和耐焊性,适用于回流炉和波峰焊。
应用于各种高频电路,如:振荡、计时电路等。
NPO贴片电容容量范围对照表
厚度与符号对应表
符号 A C E G J K M N P Q X Y Z
最大厚度
毫米(英寸)
0.33
(0.013)
0.56
(0.022)
0.71
(0.028)
0.86
(0.034)
0.94
(0.037)
1.02
(0.040)
1.27
(0.050)
1.40
(0.055)
1.52
(0.060)
1.78
(0.070)
2.29
(0.090)
2.54
(0.100)
2.79
(0.110)
0201~1206 COG(NPO)贴片电容选型表
封装尺寸 0201 0402 0603 0805 1206
工作电压 10 16 25 16 25 50 6.3 25 50 100 16 25 50 100 200 16 25 50 100 200 500
电容量
(pF)
0.5
1.0
1.2
1.5
    A
A
A
A
C
C
C
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
1.8
2.2
2.7
    A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
3.3
3.9
4.7
    A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
5.6
6.8
8.2
    A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
10
12
15
    A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
18
22
27
    A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
33
39
47
A
A
A
C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
56
68
82
A
A
A
  C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
100
120
150
A
    C
C
C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
180
220
270
      C
C
C
C
C
C
C
G
G
G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
330
390
470
      C
    G
G
G
G
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
M
M
M
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
M
560
680
820
            G
G
G
G
G
G
G
G
G
  J
J
J
J
J
J
J
J
J
J
J
J
M
M
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
P
1000
1200
1500
            G
G
G
  J
J
J
J
J
J
J
J
J
J
  J
J
J
J
J
J
J
J
J
J
J
M
Q
Q
Q
1800
2200
2700
                    J
J
J
J
J
J
J
M
M
    J
J
J
J
J
J
M
M
M
M
P
P
3300
3900
4700
                    N
N
N
N
N
N
M
M
    J
J
J
J
J
J
M
M
M
P
P
P
5600
6800
8200
                    N
N
N
N
      J
M
M
J
M
M
M
10000
12000
15000
                    N
        M
M
1210~2225 COG(NPO)贴片电容选型表
封装尺寸 1210 1812 1825 2225
工作电压 25 50 100 200 500 25 50 100 200 500 50 100 200 500 50 100 200 500
电容量
(pF)
10
12
15
        J
J
J
18
22
27
        J
J
J
33
39
47
        J
J
J
56
68
82
        J
J
J
100
120
150
        J
J
J
180
220
270
        J
J
J
330
390
470
        J
M
M
560
680
820
J
J
J
J
J
J
J
J
J
J
J
J
M
M
M
1000
1200
1500
J
J
J
J
J
J
J
J
J
J
M
M
M
K
K
K
K
K
K
K
K
K
K
K
K
M
M
M
M
M
M
M
M
M
M
M
M
  M
M
M
M
M
M
P
P
P
1800
2200
2700
J
J
J
J
J
J
J
J
J
M
Q
Q
  K
K
K
K
K
K
K
K
K
K
K
P
M
P
Q
M
M
M
M
M
M
M
M
M
  M
M
M
M
M
M
P
P
P
3300
3900
4700
J
J
J
J
J
J
J
M
M
    K
K
K
K
K
K
K
K
K
P
P
P
Q
Q
Q
M
M
M
M
M
M
M
M
M
  M
M
M
M
M
M
P
P
P
5600
6800
8200
J
J
J
J
J
J
M
    K
K
K
K
K
M
M
M
M
P
X
X
X
M
M
M
M
M
M
M
M
P
P
M
M
M
M
M
M
P
P
P
电容量
(uF)
0.010
0.012
0.015
N
N
N
N
      K
K
M
M
M
M
M
X
  M
M
M
M
M
M
  P
M
M
M
M
M
M
P
P
Y
Q
Q
Q
0.018
0.022
0.027
          M
M
M
M
M
P
      P
P
M
    M
M
P
M
Y
Y
Y
Y
Y
Q
0.033
0.039
0.047
          M
M
X
P
P
P
              P
P
P
Y
Y
Z
Z
0.068
0.082
0.1
          X
X
X
X
X
X
              P
P
Q
