Firefly-RK3128 开发板上有 CIF 接口,支持 CIF 摄像头。 在 kernel/drivers/media/video 目录里有以下 CIF 摄像头的驱动:
本章主要描述如何配置 CIF。
在 kernel/arch/arm/boot/dts/rk3128-cif-sensor.dtsi 定义摄像头列表:
rk3128_cif_sensor: rk3128_cif_sensor{ compatible = "rockchip,sensor"; status = "disabled"; CONFIG_SENSOR_POWER_IOCTL_USR = <1>; CONFIG_SENSOR_RESET_IOCTL_USR = <0>; CONFIG_SENSOR_POWERDOWN_IOCTL_USR = <0>; CONFIG_SENSOR_FLASH_IOCTL_USR = <0>; CONFIG_SENSOR_AF_IOCTL_USR = <0>; // ... skip some modules gc0329{ is_front = <1>; rockchip,powerdown = <&gpio3 GPIO_D7 GPIO_ACTIVE_HIGH>; pwdn_active = <gc0329_PWRDN_ACTIVE>; #rockchip,power = <>; pwr_active = <PWR_ACTIVE_HIGH>; #rockchip,reset = <>; #rst_active = <>; #rockchip,flash = <>; #rockchip,af = <>; mir = <0>; flash_attach = <0>; resolution = <gc0329_FULL_RESOLUTION>; powerup_sequence = <gc0329_PWRSEQ>; orientation = <0>; i2c_add = <gc0329_I2C_ADDR>; i2c_rata = <100000>; i2c_chl = <0>; cif_chl = <0>; mclk_rate = <24>; }; gc0329_b { is_front = <0>; rockchip,powerdown = <&gpio3 GPIO_B3 GPIO_ACTIVE_HIGH>; pwdn_active = <gc0329_PWRDN_ACTIVE>; #rockchip,power = <>; pwr_active = <PWR_ACTIVE_HIGH>; #rockchip,reset = <>; #rst_active = <>; #rockchip,flash = <>; #rockchip,af = <>; mir = <0>; flash_attach = <0>; resolution = <gc0329_FULL_RESOLUTION>; powerup_sequence = <gc0329_PWRSEQ>; orientation = <0>; i2c_add = <gc0329_I2C_ADDR>; i2c_rata = <100000>; i2c_chl = <0>; // <0>; cif_chl = <0>; mclk_rate = <24>; }; }; 这里列出 gc0329 双摄像头模组的配置,其属性解释如下:
其中的常量值都在 kernel/arch/arm/mach-rockchip/rk_camera_sensor_info.h 中定义:
#define gc0329_FULL_RESOLUTION 0x30000 // 0.3 megapixel #define gc0329_I2C_ADDR 0x62 #define gc0329_PWRDN_ACTIVE 0x01 #define gc0329_PWRSEQ sensor_PWRSEQ_DEFAULT //Sensor power active level define #define PWR_ACTIVE_HIGH 0x01 #define PWR_ACTIVE_LOW 0x0 分辨率对应的图像长宽,在 kernel/drivers/media/video/generic_sensor.h 的 sensor_get_full_width_height 函数里定义:
static inline int sensor_get_full_width_height(int full_resolution, unsigned short *w, unsigned short *h) { switch (full_resolution) { case 0x30000: { *w = 640; *h = 480; break; } case 0x100000: { *w = 1024; *h = 768; break; } //... } } 要启用 CIF ,只需在 kernel/arch/arm/boot/dts/rk3128-fireprime.dts 加入:
&rk3128_cif_sensor{ status = "okay"; }; 全部0条评论
