本章介绍 Buildroot 固件的编译使用。
下载repo工具:
mkdir linux cd linux git clone https://github.com/FireflyTeam/repo.git
下载 Linux-SDK:
mkdir linux-sdk cd linux-sdk # 初始化repo仓库 ../repo/repo init --repo-url https://github.com/FireflyTeam/repo.git -u https://github.com/FireflyTeam/manifests.git -b linux-sdk -m rk3288/rk3288_linux_release.xml # 同步源码 ../repo/repo sync -c
下载 Linux-SDK GPT源码包
# 把压缩包放在上一步下载repo工具的目录下 7z x linux-sdk-3288.7z # 更新代码 repo sync -c
安装编译所需工具,确保工具都正确安装:
$ sudo apt-get install git gnupg flex bison gperf build-essential \ zip tar curl libc6-dev libncurses5-dev:i386 x11proto-core-dev \ libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 \ libgl1-mesa-dev g++-multilib mingw32 cmake tofrodos \ python-markdown libxml2-utils xsltproc zlib1g-dev:i386 lzop lib32stdc++6 $ sudo ln -s /usr/lib/i386-linux-gnu/mesa/libGL.so.1 /usr/lib/i386-linux-gnu/libGL.so
sudo apt-get install git gcc-arm-linux-gnueabihf u-boot-tools device-tree-compiler mtools \ parted libudev-dev libusb-1.0-0-dev python-linaro-image-tools linaro-image-tools libssl-dev \ autotools-dev libsigsegv2 m4 libdrm-dev curl sed make binutils build-essential gcc g++ bash \ patch gzip bzip2 perl tar cpio python unzip rsync file bc wget libncurses5 libglib2.0-dev openssh-client lib32stdc++6
$ sudo apt-get install gcc-arm-linux-gnueabihf \ gcc-aarch64-linux-gnu device-tree-compiler lzop libncurses5-dev \ libssl1.0.0 libssl-dev
选择开发板对应的配置文件。配置文件会链接到 device/rockchip/.BoardConfig.mk
,查看该文件可确认当前所使用的配置文件:
./build.sh aio-3288c.mk # 文件路径在 `device/rockchip/rk3288/aio-3288c.mk`
.mk
文件默认配置为编译 Buildroot 固件,下面对 Buildroot 相关配置进行说明:
# Buildroot config export RK_CFG_BUILDROOT=rockchip_rk3288 # Buildroot 根文件系统配置文件 # 文件路径在 `buildroot/configs/rockchip_rk3288_defconfig`
# Recovery config export RK_CFG_RECOVERY=rockchip_rk3288_recovery # recovery 模式下根文件系统配置文件(可省略) # 文件路径在 `buildroot/configs/rockchip_rk3288_recovery_defconfig`
# rootfs image path export RK_ROOTFS_IMG=buildroot/output/$RK_CFG_BUILDROOT/images/rootfs.$RK_ROOTFS_TYPE # Buildroot 根文件系统镜像路径 # 本例中,文件路径在 `buildroot/output/rockchip_rk3288/images/rootfs.ext4` # 注:该文件路径将在首次编译根文件系统后生成
执行编译命令时,将会根据 .mk
文件进行编译。
全自动编译会编译并打包固件 update.img
,生成固件目录 rockdev/
./build.sh
./build.sh kernel
./build.sh uboot
编译 Buildroot 根文件系统,将会在 buildroot/output
生成编译输出目录:
./build.sh buildroot # 注:确保作为普通用户编译 Buildroot 根文件系统,避免不必要的错误。编译过程中会自动下载所需软件包,请保持联网状态
为确保 rockdev/
目录下文件链接正确,更新各部分镜像链接:
./mkfirmware.sh
将 rockdev
目录的各部分镜像打包成固件 update.img
./build.sh updateimg
Buildroot 编译输出结果保存在 output
目录,具体目录由配置文件决定,本例保存在 buildroot/output/rockchip_rk3288
目录,后续可以在该目录执行 make
编译根文件系统。
采用全自动编译方式时,默认会生成 buildroot/output/rockchip_rk3288_recovery
目录,这是 recovery
的编译输出目录。
子目录说明:
build/
包含所有的源文件,包括 Buildroot 所需主机工具和选择的包,这个目录包含所有 模块源码。host/
主机端编译需要的工具包括交叉编译工具。images/
包含压缩好的根文件系统镜像文件。staging/
这个目录类似根文件系统的目录结构,包含编译生成的所有头文件和库,以及其他开发文件,不过他们没有裁剪,比较庞大,不适用于目标文件系统。target/
包含完整的根文件系统,对比 staging/
,它没有开发文件,不包含头文件,二进制文件也经过 strip
处理。下文将介绍一些自定义 Buildroot 的方法。
默认编译好的根文件系统不一定满足我们的需求,我们可能需要增加一些第三方包,或者修改包的配置选项,Buildroot 支持图形化方式去做选择配置:
cd buildroot/output/rockchip_rk3288/ # 进入图形化配置界面,选择所需模块,保存退出 make menuconfig # 保存到配置文件 'buildroot/configs/rockchip_rk3288_defconfig' make savedefconfig #编译 Buildroot 根文件系统 make
需要了解的是:
output/build/
目录下,然后进行编译。package/
目录,Buildroot 会在解压软件包时为其打上相应的补丁。busybox 用于管理系统的命令工具,可按如下方式修改:
cd buildroot/output/rockchip_rk3288/ # 进入图形化配置界面,选择所需工具,退出保存 make busybox-menuconfig # 保存到配置文件 `board/rockchip/common/base/busybox.config` make busybox-update-config make
文件系统覆盖是指在目标文件系统编译完成后将文件覆盖到文件系统目录。通过这种方式,我们可以简单的添加或修改一些文件:
buildroot/board/rockchip/rk3288/fs-overlay
buildroot/board/rockchip/common
例:buildroot/board/rockchip/rk3288/fs-overlay/etc/firmware
将覆盖文件系统的 /etc/firmware
文件。
