fireflyAIO-3399J-创建Ubuntu根文件系统简介
创建 Ubuntu 根文件系统
准备工作
安装qemu
在Linux PC主机上安装模拟器:
sudo apt-get install qemu-user-static
下载和解压 ubuntu-core
Firefly-rk3399 ubuntu根文件系统是基于Ubuntu base 16.04来创建的。用户可以到ubuntu cdimg 下载,选择下载ubuntu-base-16.04.1-base-arm64.tar.gz 。
下载完之后,创建临时文件夹并解压根文件系统:
mkdir temp sudo tar -xpf ubuntu-base-16.04.1-base-arm64.tar.gz -C temp
修改根文件系统
准备工作
准备网络:
sudo cp -b /etc/resolv.conf temp/etc/resolv.conf
准备qemu
sudo cp /usr/bin/qemu-aarch64-static temp/usr/bin/
进入根文件系统进行操作:
sudo chroot temp
更新及安装
更新:
apt update apt upgrade
安装自己需要的功能
apt install vim git ....(根据自己需求添加)
安装xubuntu
apt install xubuntu-desktop
可能出现错误:
E: Unable to locate package xxxx
安装包的源没有添加到/etc/apt/source.list中,导致无法识别安装包,可以自行添加源,也可以使用下面给出的source.list覆盖原来的/etc/apt/source.list文件:
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to # newer versions of the distribution. deb http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main restricted ## Major bug fix updates produced after the final release of the ## distribution. deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main restricted ## Uncomment the following two lines to add software from the 'universe' ## repository. ## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu ## team. Also, please note that software in universe WILL NOT receive any ## review or updates from the Ubuntu security team. deb http://ports.ubuntu.com/ubuntu-ports/ xenial universe deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial universe deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates universe deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-updates universe ## N.B. software from this repository may not have been tested as ## extensively as that contained in the main release, although it includes ## newer versions of some applications which may provide useful features. ## Also, please note that software in backports WILL NOT receive any review ## or updates from the Ubuntu security team. deb http://ports.ubuntu.com/ubuntu-ports/ xenial-backports main restricted deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-backports main restricted deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security main restricted deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security universe deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security universe deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security multiverse deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security multiverse
添加用户及设置密码
添加用户
useradd -s '/bin/bash' -m -G adm,sudo firefly
给用户设置密码:
passwd firefly
给root用户设置密码:
passwd root
修改完自己的根文件系统就可以退出了。
exit
制作根文件系统
制作自己的根文件系统,大小依据自己的根文件系统而定,注意依据temp文件夹的大小来修改count值
dd if=/dev/zero of=linuxroot.img bs=1M count=2048 sudo mkfs.ext4 linuxroot.img mkdir rootfs sudo mount linuxroot.img rootfs/ sudo cp -rfp temp/* rootfs/ sudo umount rootfs/ e2fsck -p -f linuxroot.img resize2fs -M linuxroot.img
这样 linuxroot.img 就是最终的根文件系统映像文件了。
FAQs
根文件系统加载后,大小不正常,未占满整个分区:
在系统正确加载后执行扩展文件系统命令:
resize2fs /dev/mtd/by-name/linuxroot
