友善之臂NanoPi M4计算机介绍
  嵌入式主板
  嵌入式主板
  嵌入式主板
  嵌入式主板
  嵌入式主板
  嵌入式主板
  嵌入式主板
  嵌入式主板
  CPU Model: Rockchip RK3399
  Number of Cores: 64-bit Dual Core Cortex-A72 + Quad Core Cortex-A53
  Frequency: Cortex-A72(up to 2.0GHz), Cortex-A53(up to 1.5GHz) GPU Mali-T864 GPU,supports OpenGL ES1.1/2.0/3.0/3.1, OpenVG1.1, OpenCL, DX11, and AFBC VPU 4K VP9 and 4K 10bits H265/H264 60fps decoding, Dual VOP, etc Memory Dual-Channel 4GB LPDDR3-1866 / Dual-Channel 2GB DDR3-1866 Storage eMMC: no Onboard eMMC, but has a eMMC socket
  MicroSD Slot: MicroSD*1 for external storage up to 128GB Connectivity Ethernet: Native Gbps Ethernet
  WiFi: 802.11a/b/g/n/ac, Bluetooth 4.1, Wi-Fi and Bluetooth combo module, dual antenna interface
  Antenna*2: IPX Connector Audio Audio Output: 3.5mm Dual channel headphone jack, or HDMI
  Audio Input: microphone input interface*1 Video Input one or two 4-Lane MIPI-CSI, dual ISP, up to 13MPix/s,supports simultaneous input of dual camera data Video Output HDMI*1: HDMI 2.0a, supports 4K@60Hz,HDCP 1.4/2.2
  4-Lane MIPI-DSI*1 USB USB 3.0*4: USB 3.0 Type-A ports
  USB Type-C*1: Supports USB2.0 OTG and Power input
  USB Host*2 (included in GPIO2 2.54mm pitch pin header) Pin-header
  GPIO1: 40pin, 2.54mm pitch pin-header
  3*3V/1.8V I2C, up to 1*3V UART, 1*3V SPI, 1*SPDIF_TX, up to 8*3V GPIOs, 1*1.8V 8 channels I2S
  GPIO2: 24pin, 2.54mm pitch pin-header
  2 independent native USB 2.0 Host interfaces, PCIe x2, PWM*1, PowerKey
  Serial Debug Port: 2.54mm pitch 4-pin-header, 3V level, 1500000bps
  LED Power LED(Red)*1
  GPIO Controlled LED(Green)*1 Others RTC: 2 Pin 1.27/1.25mm RTC battery input connector
  Working Temperature: -20℃ to 70℃ Power DC 5V/3A
  嵌入式主板
  OS Support Android 7.1.2
  Lubuntu 16.04 (32-bit)
  FriendlyCore 18.04 (64-bit)
  FriendlyDesktop 18.04 (64-bit) Kernel version Linux-4.4-LTS
  U-boot-2014.10
  嵌入式主板
  PCB 8 Layer Dimension 85*56mm Weight 47.70g
  嵌入式主板
  嵌入式主板
  嵌入式主板
