友善之臂NanoPi NEO Plus2主板介绍英文版
  Linux
  Linux
  Linux
  Linux
  Linux
  Linux
  Linux
  CPU Model: Allwinner H5
  Number of Cores: 64-bit Quad-Core
  Frequency:4* Cortex-A53 1.5GHz Memory RAM: 512MB/1GB DDR3 Storage eMMC: 8GB
  MicroSD Slot: MicroSD*1 for external storage up to 128GB Connectivity Ethernet: Gbps Ethernet, RTL8211E-VB-CG chip
  WiFi: 802.11b/g/n
  Bluetooth: 4.0 dual mode
  Antenna: IPX Connector*1 Audio Input/Output: 2.54mm pitch 5 pin-header USB USB 2.0*1: USB 2.0 Host Type A
  USB pin header*2
  MicroUSB*1: Power input(5V/2A) Pin-header
  GPIO 1:
  24Pin, 2.54mm pitch double-row pin-header containing UART, SPI, I2C and IO
  GPIO 2:
  12Pin, 2.54mm pitch pin-header containing USB, IR receiver,I2S and IO
  Serial Debug Port: 2.54mm pitch 4pin-header LED Power LED(Red)*1
  STAT LED(Green)*1 Others Working Temperature: -20℃ to 70℃ Power DC 5V/2A
  Linux
  OS Support FriendlyCore(based on UbuntuCore-16.04)
  Third party: Armbian, DietPi, Lakka, Kali, OpenWrt etc Kernel version Linux-4.14-LTS
  U-boot-2017.11 FriendlyCore 64-bit OS
  supports FriendlyElec’s BakeBit Kit
  supports FriendlyElec’s NanoHAT OLED
  pre-installed FriendlyElec’s NanoHAT Motor Python Library
  pre-installed WiringPi for GPIO access
  pre-installed RPi.GPIO for GPIO access
  npi-config: system configuration utility for setting passwords, language, timezone, hostname,
  SSH and auto-login
  networkmanager: a network tility to manage networking
  auto-login with user account “pi” with access to npi-config
  supports Gbps Ethernet
  supports WiFi and Bluetooth
  supports FriendlyElec‘s FA-CAM202 USB camera
  supports audio recording and playing Debian for NAS Dock supports FriendlyElec’s NAS Dock
  pre-installed OpenMediaVault
  Linux
  PCB Six Layer Dimension 40*52mm Weight 22.20g
  Linux
