MAX3580 DVB-T Reference Design
IC应用电路图
512人已加入
Abstract: The MAX3580 DVB-T reference design meets NorDig and MBRAI requirements. This NIM design includes the MAX3580 direct-conversion tuner and a COFDM DVB-T demodulator. A discrete, active loop-through with low power consumption and low cost is included.
DVB
Figure 1. The reference design for the NorDig and MBRAI DVB-T tuner features the MAX3580.
DVB
Figure 2. System block diagram.
Lab Measurements
DVB
Figure 3. Data shows that there is at least 2dB margin to NorDig 1.0.2 in the VHF band.
DVB
Figure 4. Here the data shows that there is 3.5dB to about 5dB margin to NorDig 1.0.2 in the UHF band.
NorDig Compliance
Parameter Conditions Measured NorDig Units
Operating Frequency Range VHF-III Band: 170MHz to 230MHz
UHF Band: 470MHz to 870MHz
Sensitivity, Gaussian Channel
(VHF-III Band)
QPSK, 8k, CR = 1/2, GI = 1/4 -97.3 -94.6 dBm
16QAM, 8k, CR = 3/4, GI = 1/4 -88.5 -85.1
64QAM, 8k, CR = 7/8, GI = 1/4 -79.6 -77.2
(UHF Band)
QPSK, 8k, CR = 1/2, GI = 1/4 -96.6 -92.1 dBm
16QAM, 8k, CR = 3/4, GI = 1/4 -87.9 -82.6
64QAM, 8k, CR = 7/8, GI = 1/4 -79.6 -74.7
Maximum Input, Gaussian Channel
(VHF-III Band)
64-QAM, 8k, CR = 2/3, GI = 1/8 > 0 -35 dBm
64-QAM, 8k, CR = 2/3, GI = 1/4 > 0 -35
64-QAM, 8k, CR = 3/4, GI = 1/8 > 0 -35
(UHF Band)
Adjacent Channel Selectivity N+1 DVB-T adjacent channel 47 ≥ 28 dBc
N-1 DVB-T adjacent channel 45
N+2 DVB-T adjacent channel 47.8 ≥ 38
N-2 DVB-T adjacent channel 46
MBRAI Compliance
  Case Category Measure MBRAI Units
Selectivity, S1 Pattern N+1 Category a, b1 48 37 dBc
N+1 Category b2, c 45 37 dBc
N-1 Category a, b1 54 37 dBc
N-1 Category b2, c 51 37 dBc
N+2 Category a, b1 47 37 dBc
N+2 Category b2, c 55 37 dBc
N-2 Category a, b1 45 37 dBc
N-2 Category b2, c 58 37 dBc
Selectivity, S2 Pattern N+1 Category a, b1 and b2, c 39 29 dBc
N-1 Category a, b1 and b2, c 38 29 dBc
N+2 Category a, b1 43 40 dBc
N+2 Category b2, c 45 40 dBc
N-2 Category a, b1 42 40 dBc
N-2 Category b2, c 44 40 dBc
Linearity L1 Category a, b1 45.5 45 dBc
Category b2, c 47 45 dBc
Linearity L2 Category a, b1 45.2 45 dBc
Linearity L3 Category a, b1 40.7 40 dBc
Category b2, c 42 40 dBc
Sensitivity Details for all Modes
Seven Channels are selected to test the sensitivity for all DVB-T modes.
VHF UHF
Frequency (MHz) 177.5 226.5 474 570 674 770 858
QPSK, 8k, CR = 1/2, GI = 1/4 Sensitivity (dBm) -97.3 -97.3 -97.2 -97.1 -96.7 -96.5 -96.2
Max-Input (dBm) > 0 > 0 > 0 > 0 > 0 > 0 > 0
QPSK, 8k, CR = 2/3, GI = 1/4 Sensitivity (dBm) -95.9 -95.7 -95.7 -95.6 -95.3 -94.9 -94.8
QPSK, 8k, CR = 3/4, GI = 1/4 Sensitivity (dBm) -94.8 -94.8 -94.7 -94.6 -94.5 -94.1 -94
QPSK, 8k, CR = 5/6, GI = 1/4 Sensitivity (dBm) -93.8 -93.7 -93.6 -93.6 -93.3 -93 -92.8
QPSK, 8k, CR = 7/8, GI = 1/4 Sensitivity (dBm) -93.3 -93.1 -93.1 -92.7 -92.7 -92.4 -92.2
16QAM, 8k, CR = 1/2, GI = 1/4 Sensitivity (dBm) -91.7 -91.7 -91.5 -91.5 -91.4 -90.9 -90.7
16QAM, 8k, CR = 2/3, GI = 1/4 Sensitivity (dBm) -89.8 -89.7 -89.5 -89.5 -89.3 -88.9 -88.8
16QAM, 8k, CR = 3/4, GI = 1/4 Sensitivity (dBm) -88.6 -88.3 -88.4 -88.1 -88.1 -87.5 -87.3
16QAM, 8k, CR = 5/6, GI = 1/4 Sensitivity (dBm) -87.1 -87 -87 -86.9 -86.9 -86.4 -86.3
16QAM, 8k, CR = 7/8, GI = 1/4 Sensitivity (dBm) -86.4 -85.7 -86.1 -85.9 -85.7 -85.4 -85.6
64QAM, 8k, CR = 1/2, GI = 1/4 Sensitivity (dBm) -87 -86.9 -86.9 -86.6 -86.7 -86.2 -85.9
64QAM, 8k, CR = 2/3, GI = 1/4 Sensitivity (dBm) -84.1 -84.1 -83.8 -83.8 -83.7 -83.3 -83.2
64QAM, 8k, CR = 3/4, GI = 1/4 Sensitivity (dBm) -82.5 -82.2 -82.3 -82.4 -81.8 -81.5 -81.4
64QAM, 8k, CR = 5/6, GI = 1/4 Sensitivity (dBm) -80.9 -80.9 -80.7 -80.7 -80.4 -80.2 -79.8
64QAM, 8k, CR = 7/8, GI = 1/4 Sensitivity (dBm) -79.9 -79.7 -79.5 -79.5 -79 -78.9 -78.8
Max-Input (dBm) -2 -0.2 > 0 > 0 > 0 > 0 > 0
Supply Current
Test conditions for supply current measurements include 75Ω terminations on RF input and TV output, active working mode, and system tuned to channel 69 (858MHz).
Parameter Conditions Measured Units
5V LNA Supply Current 12 mA
5V for Tuner and LNA* {8k, QPSK, CR = 1/2, GI = 1/4} 196 mA
{8k, 64QAM, CR = 7/8, GI = 1/4} 196 mA
3.3V Digital Supply Current for Demodulator {8k, QPSK, CR = 1/2, GI = 1/4} 8 mA
{8k, 64QAM, CR = 7/8, GI = 1/4} 10 mA
2.5V Analog Supply Current for Demodulator {8k, QPSK, CR = 1/2, GI = 1/4} 36 mA
{8k, 64QAM, CR = 7/8, GI = 1/4} 36 mA
1.0V Digital Supply Current for Demodulator {8k, QPSK, CR = 1/2, GI = 1/4} 90 mA
{8k, 64QAM, CR = 7/8, GI = 1/4} 92 mA
1.0V Analog Supply Current for Demodulator {8k, QPSK, CR = 1/2, GI = 1/4} 3 mA
{8k, 64QAM, CR = 7/8, GI = 1/4} 3 mA
*Note: the MAX3580 uses 3.3V voltage drawn from a 5V LDO.
Detailed Description
This DVB-T receiver reference design is NorDig 1.0.2 and MBRAI compliant. It is intended for terrestrial set-top box applications and has a NIM form factor. The reference design covers the VHF-III band (170MHz to 230MHz) and UHF band (470MHz to 870MHz) and interfaces with a socket board for testing system performance.
The reference design includes:
  • A discrete LNA to realize an active loop-through. The loop-through has 14dB gain and less than 3.5dB noise figure, with 60mW of power consumption.
  • A MAX3580 fully integrated silicon tuner, which includes an LNA, RF and IF VGAs, mixer and lowpass filtering in the baseband stages. The tuner operates from a single 3.3V power supply. Only a small number of passive components are needed to form a complete DVB-T RF front-end solution.
  • A DVB-T/H-compliant demodulator that features the full DVB-T and DVB-H standards framing structure, channel coding, and demodulation.
  • 相关推荐
  • 热点推荐
  • DVB
  • MAX3
