MAX2165 DMB-TH USB Dongle Refe
IC应用电路图
512人已加入
MAX2165 DMB-TH USB Dongle Reference Design
Abstract: This compact USB dongle design combines a MAX2165 direct-conversion tuner and a DMB-TH demodulator. The design converts a UHF signal (470MHz to 858MHz) to a MPEG-2 transport stream. Then the USB interface enables video viewing on a laptop or desktop computer.
DMB
DMB
Figure 1. The reference design for the compact DMB-TH USB dongle features the MAX2165.
DMB
More detailed image (PDF, 232kB)
Figure 2. System block diagram.
Lab Measurements
MAX2165 Noise Figure and Maximum Gain
DMB
Figure 3. The noise figure ranges from 3.0dB to 4.3dB, with maximum gain ranging from 79.2dB to 81.8dB over 474MHz to 858MHz.
MAX2165 Phase Noise at 474MHz
DMB
Figure 4. Phase noise at 1.0kHz offset is -99dBc/Hz when the LO frequency is 474MHz.
RF Input Return Loss
DMB
Figure 5. The input return loss is better than -7.7dB from 474MHZ to 858MHz when the LO frequency is 858MHz.
Detailed Description
This DMB-TH receiver reference design includes the MAX2165 direct-conversion tuner, a DMB-TH demodulator, and USB interface circuitry. This solution is intended for handheld or laptop computer-based digital video broadcast applications in the Chinese market. The design covers the 470MHz to 858MHz UHF band.
The MAX2165 direct-conversion architecture eliminates the need for an IF-SAW filter. Programmable baseband channel-selection filters allow for operation with 7MHz and 8MHz channels. The fractional-N synthesizer reduces VCO lock time and minimizes close-in phase noise, thus eliminating the need for power-hungry, phase-noise reduction algorithms.
The DMB-TH demodulator accepts I/Q inputs from the tuner and supplies a MPEG-2 transport stream to the USB chip. The USB chip enables interfacing with a laptop or desktop computer for viewing broadcast video and for lab analysis.
  • 相关推荐
  • 热点推荐
  • DMB
