±15kV ESD-Protected, Single-/D
新品快讯
29人已加入
±15kV ESD-Protected, Single-/Dual-Channel, Bidirectional Low-Level Translators in Tiny Packages
  • The MAX13046E/MAX13047E are ±15kV ESD-protected, single-/dual-channel, bidirectional level translators.
  • These devices save board space while providing enhanced protection for applications that route signals externally.
  • To save space, these level translators integrate robust ESD-protection circuitry in tiny µDFN, TDFN, and UTQFN packages.
  • The MAX13046E/MAX13047E are ideal for data transfer between low-voltage ASICs/PLDs and higher-voltage systems.
SUNNYVALE, CA—August 18, 2008—Maxim Integrated Products (PINK OTC MARKETS: MXIM) introduces the MAX13046E/MAX13047E ±15kV ESD-protected, single-/dual-channel, bidirectional level translators. Designed to provide level shifting for data transfer in multivoltage systems, these devices accept a VL voltage from 1.1V to either 3.6V or (VCC + 0.3V), whichever is lower, and a VCC from 1.65V to 5.5V. Over these specified voltage ranges, the MAX13046E/MAX13047E operate at a guaranteed data rate of 8Mbps; within specific voltage domains, higher data rates are possible. Integrating ±15kV ESD-protection circuitry in tiny µDFN, TDFN, and UTQFN packages, these devices save board space while providing enhanced protection for applications that route signals externally. Consequently, the MAX13046E/MAX13047E are ideal for data transfer between low-voltage ASICs/PLDs and higher-voltage systems.
The MAX13046E/MAX13047E also feature thermal short-circuit protection and a shutdown mode that reduces the supply current to less than 1µA. Fully specified over the -40°C to +85°C extended temperature range, the MAX13046E is available in a 1mm x 1.5mm, 6-pin µDFN package, while the MAX13047E is available in 2mm x 2mm, 8-pin TDFN and tiny, 1.4mm x 1.8mm, 10-pin UTQFN packages. Prices start at $0.90 (1000-up, FOB USA).
  • 相关推荐
  • 热点推荐
  • ESD
