焊管理论重量及包装支数的规定
焊接与组装
185人已加入
焊管理论重量及包装支数的规定
规格∮ 壁厚mm   kg/m   支/捆        规格∮   壁厚mm   kg/m     支/捆
15mm   2.00       0.95   169         140mm     3.50     11.78     19
15mm   2.20       1.04   169         140mm     3.75     12.60      19
15mm   2.30       1.08   169         140mm     4.00     13.42     19
15mm   2.40       1.12   169         140mm     4.25     14.23     19
15mm   2.50       1.16   169         140mm     4.50     15.04     19
15mm   2.65       1.22   169         140mm     4.75     15.48     19
15mm   2.75       1.26   169         140mm     5.00     16.65     19
20mm   2.00       1.22   127         140mm     5.25     17.45      19
20mm   2.20       1.33   127         140mm     5.50     18.24     19
20mm   2.30       1.39   127         140mm     5.75     19.04     19
20mm   2.40       1.44   127         140mm     6.00     19.38     19
20mm   2.50       1.50   127         159mm     3.50     13.42      7
20mm   2.65       1.58   127         159mm     3.75      14.36      7
20mm   2.75       1.63   127         159mm     4.00     15.29      7
25mm   2.50       1.91    91          159mm     4.50     17.14      7
25mm   2.75       2.09    91          159mm     4.75     18.07      7
25mm   3.00       2.26    91          159mm     5.00     18.99      7
25mm   3.10       2.32    91          159mm     5.50     20.82      7
25mm   3.15       2.36    91           159mm     5.75     21.73      7
25mm   3.25       2.42    91          159mm     6.00     22.64      7
32mm   2.75       2.68    61           159mm     7.00     26.24      7
32mm   3.00       2.91    61          165mm     3.50     13.94      7
32mm   3.10       3.00    61          165mm     3.75     14.91      7
32mm   3.15       3.04    61          165mm     4.00     15.88      7
32mm   3.25       3.13    61          165mm     4.25     16.85      7
40mm   2.50       2.81    61          165mm     4.50     17.81      7
40mm   2.60       2.91    61           165mm     4.75     18.77      7
40mm   2.75       3.07    61           165mm     5.00     19.73      7
40mm   3.00       3.33    61           165mm     5.25     20.68      7
40mm   3.10       3.43    61           165mm     5.50     21.63      7
40mm   3.25       3.59     61          165.1mm   3.50     13.95      7
40mm   3.30       3.64    61          165.1mm   3.75     14.92      7
40mm   3.40       3.74    61          165.1mm   4.00     15.89      7
40mm   3.50       3.84    61          165.1mm   4.25     16.86      7
50mm   2.50       3.54    37          165.1mm   4.50     17.82      7
50mm   2.75       3.88    37          165.1mm   4.75     18.78      7
50mm   3.00       4.22    37          165.1mm   5.00     19.74      7
50mm   3.10       4.35    37          165.1mm   5.25     20.69      7
50mm   3.25       4.55    37          165.1mm   5.50     21.65      7
50mm   3.30       4.61    37          165.1mm   5.75     22.60      7
50mm   3.40       4.75    37          165.1mm   6.00     23.54      7
50mm   3.50       4.88    37          165.1mm   6.25     24.48      7
65mm   3.00       5.36    37          165.1mm   6.50     25.42      7
65mm   3.10       5.53    37          165.1mm   6.75     26.36       7
65mm   3.25       5.79    37          165.1mm   7.00     27.29      7
65mm   3.30       5.88    37            219mm     4.00     21.22      7
65mm   3.40       6.05    37            219mm     4.25     22.52      7
65mm   3.50       6.21    37            219mm     4.50     23.81      7
65mm   3.65       6.47    37            219mm     4.75     25.11      7
65mm   3.75       6.64    37            219mm     5.00     26.40      7
80mm   3.00       6.33    19            219mm     5.25     27.69      7
80mm   3.10       6.53    19            219mm     5.50     28.97      7
80mm   3.25       6.83    19            219mm     5.75     30.25      7
80mm   3.30       6.93    19            219mm     6.00     31.53      7
80mm   3.50       7.34    19            219mm     6.25     32.81      7
80mm   3.65       7.64    19            219mm     6.50     34.08      7
80mm   3.75       7.84    19            219mm     6.75     35.35      7
100mm 3.00       8.21    19            219mm     7.00     36.61      7
100mm 3.25       8.88    19            219mm     7.25     37.88       7
100mm 3.40       9.27    19            219mm     7.50     39.14      7
100mm 3.50       9.54    19            219mm     7.75     40.39      7
100mm 3.65       9.93    19            219mm     8.00     41.65       7
100mm 3.75       10.20   19            219mm     8.25     42.90       7
100mm 4.00      10.85   19            219mm     8.50     44.14      7
100mm 4.25      11.50   19            219mm     8.75     45.39      7
100mm 4.50      12.15   19            219mm     9.00     46.63      7
100mm 4.75      12.80   19            219mm     9.25     47.87      7
100mm 5.00      13.44   19            219mm     9.50     49.10       7
100mm 5.25      14.08   19            219mm     9.75     50.34      7
100mm 5.50      14.72   19            219mm    10.00    51.56      7
  • 相关推荐
  • 热点推荐
  • 重量
