源创通信IPP200 USB 手柄电话介绍
  • 产品型号   IPP200
  • 产品描述
    ipp200 is a USB phone.
    sinovoip ODM for eutecticsinc
    if you like this product. please visit:http://www.eutecticsinc.com/
WINDOWS
产品介绍
Internet Power Phone 200™ V2012 Handset
The Internet Power Phone 200™ V2012 is the simplest and most cost effective of the Internet Power Phone™ product line. The IPP 200™ V2012 is able to operate seamlessly with all popular VoIP Client software and has been tested with Cisco, 3Com NBX, Xten, Nortel, Dialpad and Windows Messenger. Client hook-switch integration (optional) requires the installation of Eutectics integration software.
WINDOWS
 IPP200 Handset
  • ABS
    • Shock       resistant
  • 2      piece construction with mounting structures
    • weighted
    • strain       relief
    • RJ9       Female receptacle
    • PCB       mounting receptacle
    • Microphone       receptacle
    • Speaker       Receptacle
    • Volume       controls access port
  • Minimal      Acoustic Coupling shell
  • Ergonomic      design
  • USB     1.1 compliant Cord
  • Shielded
  • USB      A termination
  • 1.3      meters length
  • Coiled
  • Strain      relief
  • Hookswitch
  • Magnetic
  • Low      profile
  • Indicator      Light (Blue)
  • Cradle
  • ABS
  • Wall      or Desktop Mountable
  • Passive      Magnetic contact coupling
  • One      piece construction moulded
    • Weighted
    • Magnetic
Functional Specification
  • DTMF     Dialling
    • PC      Client Supported
  • Outbound     Local Dialtone
    • PC      originated
  • Inbound     Ring
    • PC      Based Ringer
    • Optional      Built In Ringer
    • Optional      Distinctive ring
  • Mute
  • Volume     Up/Down
  • Full     Client Integration
Configuration
  • Remote     Configurable
  • Remote     Software Upgrade
  • Local     Configuration
    • Via      PC Software
Connections
·         USB A
·         RJ9
·         Bus Powered
Client VoIP Supported Protocols
  • Optional     H.323 Stack
    • Via      Netmeeting
  • Optional     SIP Stack
    • Via      Windows XP
    • IETF      Standard
  • Optional     Net2Phone Stack
    • Proprietary      Signalling
  • Optional     MGCP 1.1
  • Optional     H.248
Components
  • Micro     Controller
    • 8031/51      Series
    • ASIC      device
  • Local     Program Memory
  • Database
  • USB     Transceivers
  • I2CController
Ancillary Services Integration(Client Dependent)
  • Voice     Mail
  • Message     Waiting
  • Three     Party Calling
  • Call     Waiting
  • Caller     ID
Standards and compatibility
·         USB 1.1 – USB-IF Compliance
o        VID 0x0E7D – Internet Power Phone
·         FCC part 15 (Class B)
·         CE
·         UL
·         Microsoft WDM/ODM
Network management
  • Interfaces (Client     Dependant)
    • HTML, JAVA, SOAP, XML
    • CORBA, RMI, DCOM, JDBC
    • SNMP, TL1, CMIP/Q3,      Adapters
  • All NMS Platforms are     supported
  • MIB – Client Dependent
  • COM/DCOM events     supported by API
  • Applications (Client     Dependant – Supported by API
    • Config
    • Fault
    • Acct
    • Performance
  • UI/GUI (Client     Dependant)
    • Web Based
    • Windows
  • MIB
    • Client Dependant
  • User Management
    • Client Dependant
  • Service Management
Product Support
·         Product Support Tier I provided by VAR
·         Product Support Tier II provided by OEM (Eutectics)
·         All products 100% factory tested
·         ISO 9002 certified production facilities
·         90 day factory warranty
Software/Firmware Upgrades
·         PC Software including API and DLL via web download/install
·         Firmware Upgrade via programmable memory
·         CMOS Upgrade via programmable I2Cmemory
IPP 200™ V2012 Handset Installation process
The Eutectics IPP 200™ V2012 Handset is fully supported by native Microsoft Windows drivers (Win98 SE and later versions). Eutectics DLL and API Software is compliant to Windows 98 SE, Windows ME and Windows 2000.
Minimum requirements:
  • 100     MHz or better Pentium
  • 40     MB free storage space on Hard Drive
  • USB     Interface
  • Internet     Connection
Process:
       Refer to IPP200 Handset Installation Guide.Pdf
Availability and timescales
The IPP 200 is in full production.
