93c46读写程序
控制/MCU
1932人已加入
93c46读写程序
“93c46读写程序”
#include
sbit CS=P2^7;
sbit SK=P2^6;
sbit DI=P2^5;
sbit DO=P2^4;
extern unsigned char ReadChar(unsigned char address);
extern void WriteChar(unsigned char address,unsigned char InData);
extern void ReadString(unsigned char data *RamAddress,unsigned char RomAddress,
unsigned char Number);
extern void WriteString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number);
// Write enable must precede all programming modes.
void Ewen(void) {
 unsigned char temp,InData;
 CS=0;
 SK=0;
 CS=1;
 InData=0x98; // 10011XXXX
 for(temp=9;temp!=0;temp--) { // 9
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
 CS=0;
// Disables all programming instructions.
void Ewds(void) {
 CS=0;
 SK=0;
 CS=1;
 InData=0x80; // 10000XXXX
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
 CS=0;
// Reads data stored in memory, at specified address.
unsigned int Read(unsigned char address) {
 unsigned char temp;
 unsigned int result;
 Ewen();
 SK=0; DI=1; // 110 A5-A0
 CS=0; CS=1;
 SK=1; SK=0;   // 1
 address=address&0x3f 0x80;
 for(temp=8;temp!=0;temp--) { // 8
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
 DO=1;
 for(temp=16;temp!=0;temp--) { // 16
  SK=1;
  result=(result<<1) DO;
  SK=0;
 CS=0;
 Ewds();
 return(result);
// Writes memory location An - A0.
void Write(unsigned char address,unsigned int InData) {
 unsigned char temp;
 Ewen();
 SK=0; DI=1; // 101 A5-A0
 CS=0; CS=1;
 SK=1; SK=0;   // 1
 address=address&0x3f 0x40;
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
  DI=InData&0x8000;
  SK=1; SK=0;
  InData<<=1;
 CS=0; DO=1;
 CS=1; SK=1;
 while(DO==0) {   // busy test
  SK=0; SK=1;
 SK=0; CS=0;
 Ewds();
// Erase memory location An - A0.
void Erase(unsigned char address) {
 unsigned char temp;
 Ewen();
 SK=0; DI=1; // 111 A5-A0
 CS=0; CS=1;
 SK=1; SK=0;   // 1
 address =0xc0;
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
 CS=0; DO=1;
 CS=1; SK=1;
 while(DO==0) {
  SK=0; SK=1;
 SK=0; CS=0;
 Ewds();
// Erases all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Eral(void) {
 Ewen();
 CS=0;
 SK=0;
 CS=1;
 InData=0x90; // 10010XXXX
  DI=InData&0x80;
  SK=1; SK=0;
  InData<<=1;
 CS=0; DO=1;
 CS=1; SK=1;
 while(DO==0) {
  SK=0; SK=1;
 SK=0; CS=0;
 Ewds();
// Writes all memory locations. Valid only at VCC = 4.5V to 5.5V.
void Wral(unsigned int InData) {
 unsigned char temp,address;
 Ewen();
 CS=0;
 SK=0;
 CS=1;
 address=0x88; // 10001XXXX
  DI=address&0x80;
  SK=1; SK=0;
  address<<=1;
  DI=InData&0x8000;
  SK=1; SK=0;
  InData<<=1;
 CS=0; DO=1;
 CS=1; SK=1;
 while(DO==0) {
  SK=0; SK=1;
 SK=0; CS=0;
 Ewds();
unsigned char ReadChar(unsigned char address) {
 unsigned char temp=address>>1;
 if(address&0x01) return((unsigned char)(Read(temp)>>8));
 else return((unsigned char)(Read(temp)));
void WriteChar(unsigned char address,unsigned char InData) {
 if(address&0x01) Write(temp,(unsigned int)(Read(temp)&0x00ff (InData<<8)));
 else Write(temp,(unsigned int)(Read(temp)&0xff00 InData));
void ReadString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number) {
 while(Number!=0) {
  *RamAddress=ReadChar(RomAddress);
  RamAddress++;
  RomAddress++;
  Number--;
void WriteString(unsigned char data *RamAddress,unsigned char RomAddress,unsigned char Number) {
 unsigned int temp;
 if(Number==0) return;
 if(RomAddress&0x01) {
  WriteChar(RomAddress,*RamAddress);
  RamAddress++;
  RomAddress++;
  Number--;
 while(Number>>1) {
  temp=*RamAddress;
  RamAddress++;
  temp=temp (*RamAddress)<<8;
  RamAddress++;
  Write(RomAddress>>1,temp);
  RomAddress++;
  RomAddress++;
  Number--;
  Number--;
 if(Number) WriteChar(RomAddress,*RamAddress);
