工艺综述
IEC 2006年12月中、下旬颁布的新标准目录
标准号 |
颁布时间 |
英 文 名 称 |
中文名称 |
分类编码 |
IECEE CB-112C |
20 December 2006 |
Adherence to IEC Standards - Product Category: EMC |
IEC标准附录---产品目录:EMC |
IECEE CB-112B |
20 December 2006 |
Adherence to IEC Standards - Product Categories: HOUS, LITE, PV & TOOL |
IEC标准附录---产品目录:HOUS, LITE, PV & TOOL |
IECEE CB-112A |
20 December 2006 |
Adherence to IEC Standards - Product Categories: BATT, CABL,CAP,CONT, INST, MEAS, MED, MISC, OFF, SAFE, POW, PROT, TOYS & TRON |
IEC标准附录---产品目录:BATT, CABL,CAP,CONT, INST, MEAS, MED, MISC, OFF, SAFE, POW, PROT, TOYS & TRON |
IECEN/TRF 60335-2-30 |
20 December 2006 |
This Test Report Form applies to IEC 60335-2-30:2002 + A12004; IEC 60335-1:2001 (incl. Corrigendum 1:2002) + A1: 2004 + A2:2006 (incl. Corrigendum 1:2006) and/or EN 60335-2-30:2003 + A1: 2004; EN 60335-1:2002 + A1:2004 + A11:2004 + A12:2006 + A2:2006 |
该试验报告适用于IEC 60335-2-30:2002 + A12004; IEC 60335-1:2001 (包括 勘误表1:2002) + A1: 2004 + A2:2006 (包括勘误表1:2006) 和EN 60335-2-30:2003 + A1: 2004; EN 60335-1:2002 + A1:2004 + A11:2004 + A12:2006 + A2:2006 |
IEC/TRF 60745-2-15 |
20 December 2006 |
This Test Report Form applies to IEC 60 745-2-15:2006 (Second Edition) used in conjunction with IEC 60745-1:2006 - Edition 4.1 (Fourth Edition) |
该试验报告适用于IEC 60 745-2-15:2006 (2版) ,与 IEC 60745-1:2006 - 4.1版 (4版)一起连用 |
IEC/TRF 60335-2-29 |
20 December 2006 |
This Test Report Form applies to IEC 60335-2-29:2002 (4th edition); IEC 60335-1:2001 (4th edition) |
该试验报告适用于IEC 60335-2-29:2002 (4版), IEC 60335-1:2001 (4版) |
IECEN/TRF 60335-2-7 |
20 December 2006 |
This Test Report Form applies to IEC 60335-2-7:2002 (6.Edition) + A1:2004 + A2:2006; and/or IEC60335-1:2001 (4. Edition) (incl. Corrigendum 1:2002) + A1:2004 + A2:2006 (incl. Corrigendum 1:2006); EN 60335-1:2002 + A1:2004 + A11:2004 + A12:2006 + A2:2006; EN 60335-2-7:2003 +A1:2004 + A2:2006; EN 50366:2002 + A1:2006 |
该试验报告适用于IEC 60335-2-7:2002 (6版) + A1:2004 + A2:2006和IEC60335-1:2001 (4. 版) (包括勘误表1:2002) + A1:2004 + A2:2006 (包括勘误表1:2006)以及EN 60335-1:2002 + A1:2004 + A11:2004 + A12:2006 + A2:2006; EN 60335-2-7:2003 +A1:2004 + A2:2006以及EN 50366:2002 + A1:2006 |
MISC CENT-CHAL |
15 December 2006 |
International Standardization as a Strategic Tool |
作为战略工具的信息标准化 |
IEC 61400-25-2 |
4 December 2006(1) |
Wind turbines - Part 25-2: Communications for monitoring and control of wind power plants - Information models |
风力涡轮---第25-2部分:风力工厂监控通信---信息模式 |
27.180. |
IEC 61400-25-1 |
14 December 2006 |
Wind turbines - Part 25-1: Communications for monitoring and control of wind power plants - Overall description of principles and models |
风力涡轮---第25-1部分:风力工厂监控通信---原则和模式的全部描述 |
27.180. |
IEC 60027-6 |
14 December 2006 |
Letter symbols to be used in electrical technology - Part 6: Control technology |
电气技术用滋补符号---第6部分:控制技术 |
01.060. |
IEC 62441 |
14 December 2006 |
Accidentally caused candle flame ignition for audio/video, communication and information technology equipment |
音频/电视,通信和信息技术设备偶然引起的烛光点火 |
35.020. ; 35.260. |
IEC 62461 |
14 December 2006 |
Radiation protection instrumentation - Determination of uncertainty in measurement |
辐射保护设备---测量中的不确定的判定 |
13.280. |
IEC 62257-7-1 |
14 December 2006 |
Recommendations for small renewable energy and hybrid systems for rural electrification - Part 7-1: Generators - Photovoltaic arrays |
乡村电气化的小型更新能源和混合系统推荐标准---第7-1部分:发电机---光电部署 |
27.160. ; 27.180. |
IEC 61987-1 |
14 December 2006 |
Industrial-process measurement and control - Data structures and elements in process equipment catalogues - Part 1: Measuring equipment with analogue and digital output |
光电加工和控制---加工设备目录中的数据结构和单元---第1部分: 具有类似数字输出的测量设备 |
25.040.40; 35.240.50 |
IEC 61169-16 |
14 December 2006 |
Radio-frequency connectors - Part 16: Sectional specification - RF coaxial connectors with inner diameter of outer conductor 7 mm (0,276 in) with screw coupling - Characteristics impedance 50 ohms (75 ohms) (type N) |
音频连接器---第16部分:分规范---具有用螺钉连接的7mm外部导体内径的RF周详连接器---特性阻抗为50欧姆(75 ohms)(N型) |
33.120.30 |
IEC 60034-27 |
14 December 2006 |
Rotating electrical machines - Part 27: Off-line partial discharge measurements on the stator winding insulation of rotating electrical machines |
旋转电机---第27部分:在旋转电机的缠绕绝缘体定子上的局部离线放电测量 |
29.160. |
IEC 62350 |
14 December 2006 |
Guidance for the correct use of residual current-operated protective devices (RCDs) for household and similar use |
家用和类似用残留工作电流保护装置的正确使用指南 |
29.120.50 |
IEC 61400-25-3 |
14 December 2006 |
Wind turbines - Part 25-3: Communications for monitoring and control of wind power plants - Information exchange models |
风力涡轮---第25-3部分:风力工厂的监控通信---信息交换模式 |
27.180. |
IEC 61400-25-5 |
14 December 2006 |
Wind turbines - Part 25-5: Communications for monitoring and control of wind power plants - Conformance testing |
风力涡轮---第25-5部分:风力工厂的监控通信---符合性试验 |
27.180. |
IEC 60601-1-SER |
14 December 2006 |
Medical electrical equipment - ALL PARTS |
医用电气设备---所有部分 |
11.040. ; 11.040.01; 33.100. |
IEC 61400-SER |
13 December 2006 |
Wind turbine generator systems - ALL PARTS |
风力涡轮发电系统---所有部分 |
27.180. |
IEC 60287-1-1 |
13 December 2006 |
Electric cables - Calculation of the current rating - Part 1-1: Current rating equations (100 % load factor) and calculation of losses - General |
电缆---额定电流的计算---第1-1部分: 额定电流平衡(100 % 负载因素)和损耗考虑---总则 |
29.060.20 |
IEC 62045-1 |
13 December 2006 |
Multimedia security - Guideline for privacy protection of equipment and systems in and out of use - Part 1: General |
多媒体安全性---使用中和使用后的设备和系统的保护指南---第1部分:总则 |
33.160.60; 35.040. |
IEC 61300-3-10 |
13 December 2006 |
Fibre optic interconnecting devices and passive components - Basic test and measurement procedures - Part 3-10: Examinations and measurements - Gauge retention force |
光学纤维互连器件和无源元件---基本试验和测量程序---第3-10部分:检查和测量---标准保持力 |
33.180.20 |
IEC 61161 |
13 December 2006 |
Ultrasonics - Power measurement - Radiation force balances and performance requirements |
超声波---能量测量---辐射力平衡性能要求 |
17.140.50 |
IEC 61025 |
13 December 2006 |
Fault tree analysis (FTA) |
失效树分析(FTA) |
03.120.01; 03.120.99 |
IEC 61000-2-14 |
13 December 2006) |
Electromagnetic compatibility (EMC) - Part 2-14: Environment - Overvoltages on public electricity distribution networks |
电磁兼容性(EMC)---第2-14部分:环境---公共电流分配网络上的过电压 |
29.240. ; 33.100. |
IEC 61340-3-1 |
13 December 2006 |
Electrostatics - Part 3-1: Methods for simulation of electrostatic effects - Human body model (HBM) electrostatic discharge test waveforms |
静电学---第3-1部分:模拟静电作用方法---人体模型(HBM)---静电放电试验波形 |
17.220.99; 29.020. |
IEC 61340-3-2 |
13 December 2006 |
Electrostatics - Part 3-2: Methods for simulation of electrostatic effects - Machine model (MM) electrostatic discharge test waveforms |
静电学---第3-2部分:模拟静电作用方法---机械模型(MM) ---静电放电试验波形 |
IEC 60601-1 Corr.1 |
12 December 2006 |
Corrigendum 1 - Medical electrical equipment - Part 1: General requirements for basic safety and essential performance |
勘误表1---医用电器设备---第1部分:基本安全和主要性能总要求 |
11.040. |
IEC 62056-46-am1 |
12 December 2006 |
Amendment 1 - Electricity metering - Data exchange for meter reading, tariff and load control - Part 46: Data link layer using HDLC protocol |
勘误表1---电表---以表读数数据转换, 价格表和负载控制---第46部分:使用HDLC 协议的数据连结层 |
91.140.50; 35.100.20 |
IEC 60027-4 |
11 December 2006 |
Letter symbols to be used in electrical technology - Part 4: Rotating electric machines |
电工技术用的字模符号---第4部分:旋转式电机 |
01.060. |
IEC 62056-53 |
11 December 2006 |
Electricity metering - Data exchange for meter reading, tariff and load control - Part 53: COSEM application layer |
电流测量---仪表读数数据测量,价目表和负载控制---第53部分:COSEM 应用层 |
91.140.50; 35.100.70 |
