MAX9519 超小尺寸视频滤波放大器,提供智能化电源监测和
新品快讯
29人已加入
MAX9519 超小尺寸视频滤波放大器,提供智能化电源监测和Autoshutdown功能
Packaged in a 1mm x 1mm UCSP™ with 4 bumps, the MAX9519 is an ultra-small standard-definition video filter amplifier with automatic shutdown.
The automatic shutdown circuitry eliminates the need for a shutdown control. This feature provides intelligent power management by disabling the filter and output amplifier in the absence of a video input signal and/or an output video load. At shutdown, the device consumes only 1.8µA.
The MAX9519 features an internal reconstruction filter that smooths the steps and reduces the spikes on the video signal from the video digital-to-analog converter (DAC). The reconstruction filter typically has ±1dB passband flatness to 9MHz and typically 48.5dB of attenuation at 27MHz.
The video input to the MAX9519 can be directly connected to the DAC output. The MAX9519 has an internal fixed gain of 4V/V and expects a nominal full-scale video input signal of 0.5VP-P. The MAX9519 is specified to operate over the -40°C to +125°C automotive temperature range.
MAX9519关键特性
  • Ultra-Small, 4-Bump, 1mm x 1mm UCSP
  • Automatic Shutdown
  • DC-Coupled Input and Output
  • 2.7V to 3.6V Single-Supply Operation
  • Reconstruction Filter with 9MHz Passband and 48.5dB Attenuation at 27MHz
  • 1.8µA Shutdown Supply Current
  • MAX9519应用/使用
    数码相机(DSC)
    数字摄像机(DVC)
    移动电话
    便携或空间受限产品
    • 相关推荐
    • 热点推荐
