君正集成电路 T10嵌入式主板介绍
嵌入式主板
君正集成电路
君正集成电路
• 专业级成像ISP和H.264编码(960P)
• 高性能处理器支持智能分析(>1G CPU,128Bits SIMD引擎)
• 业内最低功耗(典型功耗390mW 含DDRII)
芯片框图
  芯片规格
CPU
XBurst single core, up to 1GHz.
MXU2.0 IVS Engine, innovative 128 bit SIMD extension instruction
32KB L1 I-cache and 32KB L1 D-cache.
128KB L2 unified cache.
Hardware floating point unit.
Encoder engine
H.264 baseline, main profile
MJPEG/JPEG Baseline
Encode Performance
Max resolution 1280x960
Up to H.264 960P@40fps encode
H.264 multiple streams
--720P@30fps+VGA@30fps+JPEG@15fps
--960P@30fps+VGA@30fps+JPEG@15fps
ABR/VBR/CBR/CQP
8 ROIs
5-layer OSD with hardware
ISP
AE, AWB, AF
Lens shading correction
Advanced spatial noise reduction
Motion-adaptive temporal noise reduction (3D de-noise)
Multi-exposure HDR image fusion (WDR)
Space-variant HDR processing
Host tuning tools
Memory
Embedded DDRII@400Mhz
Maximum capacity of 512Mbit
Computer Vision
Motion Detection/Perimeter Protection
Face Detection
Human Detection
People Counting
License Plate Recognition
CMOS Sensor
Maximum 12 bit HSYNC/VSYNC (DVP)
I2C sensor control, Flash and DC control
Programmable sensor clock output
Up to 100M pixels/s input
Audio
Embedded audio CODEC.
AAC, G726, G711, PCM encoding
Echo cancellation
On-chip Peripherals
POR, RTC, WDT
2 channel ADC
UART x 2, I2C x 2, SPI x 2, GPIO x 12
SDIO x 2, support SDHC
PWM x 4
USB OTG
RMII EMAC, support PHY clock output.
Security
AES/DES/3DES by Hardware
Global unique Chip ID
32Byte customer OTP
Physical Feature
Less than 400mW power consumption including DDRII
TFBGA181 ROHS, ball pitch of 0.65mm,body size of 10mmx10mm
OS
Linux-3.10.
