君正集成电路开发平台 Halley2介绍
嵌入式主板
君正集成电路
Halley2 系统框图
君正集成电路
 Halley2 模组详细规格
PHYSICAL 物理规格
Form factor
94-pin 镀金半孔PCB板.
Dimensions
26 x 37 x 3 mm.
ON-BOARD COMPONENTS 板上器件
Processor
Ingenic X1000E SOC, up to 1.0 GHz.
  - Embedded 64MB LPDDR.
  - Embedded high quality audio CODEC.
Memory
32MB SPI NOR flash.(Compatible with SPI NAND flash)
Wi-Fi
AP6214A(BCM43438) single-band 2.4GHz IEEE 802.11b/g/n.
Bluetooth
AP6214A(BCM43438)Bluetooth 4.1 (Bluetooth Low Energy), Bluetooth 3.0, Bluetooth 2.1 + EDR.
  POWER
  DC/DC(1.25V,1.8V,3.3V),LDO(2.5V)
Clocks
24MHz, 32.768kHz; 26MHz (Wi-Fi/BT).
EXTERNAL INTERFACES 外部扩展接口 (注:数字为最大支持的通道数,某些接口管脚功能复用)
Display
8/9/16-bit, SLCD.
Digital MIC
x 4.
Analog MIC
x 1.
Line-In
x 1.
Camera
8-bit, DVP.
  SD Card
  x 1.
USB OTG
Host & Client Modes .
 I2S
  Master & Slave Modes.
  I2C
  x 3.
  UART
  x 2.
  SPI
  x 2.
  PWM
  x 5.
  Ethernet MAC
  10/100 Mbps, RMII Interface.
JTAG
Standard EJTAG interface.
POWER 供电
Input
5V DC.
Power consumption
Standby (no radio): 2mW.
Average: 200mW, Maximum (with radio): 700mW
SOFTWARE 软件支持
Supported OS
Linux 3.10.
Code availability
Open source.
