MAX8211, MAX8212 微处理器电压监视器,可编程
新品快讯
29人已加入
MAX8211, MAX8212 微处理器电压监视器,可编程检测电压
Maxim's MAX8211 and MAX8212 are CMOS micropower voltage detectors that warn microprocessors (µPs) of power failures. Each contains a comparator, a 1.5V bandgap reference, and an open-drain n-channel output driver. Two external resistors are used in conjunction with the internal reference to set the trip voltage to the desired level. A hysteresis output is also included, allowing the user to apply positive feedback for noise-free output switching.
The MAX8211 provides a 7mA current-limited output sink whenever the voltage applied to the threshold pin is less than the 1.5V internal reference. In the MAX8212, a voltage greater than 1.5V at the threshold pin turns the output stage on (no current limit).
The CMOS MAX8211/MAX8212 are plug-in replacements for the bipolar ICL8211/ICL8212 in applications where the maximum supply voltage is less than 16.5V. They offer several performance advantages, including reduced supply current, a more tightly controlled bandgap reference, and more available current from the hysteresis output.
关键特性
  • µP Power-Fail Warning
  • Improved 2nd Source for ICL8211/ICL8212
  • Low-Power CMOS Design
  • 5µA Quiescent Current
  • On-Board Hysteresis Output
  • ±40mV Threshold Accuracy (±3.5%)
  • 2.0V to 16.5V Supply-Voltage Range
  • Define Output Current Limit (MAX8211)
  • High Output Current Capability (MAX8212)
应用/使用
  • µP电压监视
  • 备用电池切换
  • 低电池检测
  • 过压检测
  • 电源故障监视
  • 欠压检测
    MAX8211, MAX8212应用电路
    • 相关推荐
    • 热点推荐
