新品快讯
MAX9928, MAX9929 -0.1V至+28V输入范围、微功耗、单/双向电流检测放大器
The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal for monitoring battery charge and discharge currents in notebooks, cell phones, and other portable equipment. These devices feature a wide -0.1V to +28V input common-mode voltage range, low 20µA supply current with VOS less than 0.4mV, and a gain accuracy better than 1.0%. The input common-mode range is independent of the supply voltage, ensuring that the current-sense information remains accurate even when the measurement rail is shorted to ground.
The MAX9928F/MAX9928T feature a current output with transconductance ratios of 5µA/mV and 2µA/mV, respectively. An external resistor converts the output current to a voltage, allowing adjustable gain so that the input sense voltage can be matched to the maximum ADC input swing. The MAX9929F/MAX9929T have a voltage output and integrate a 10kΩ output resistor for fixed voltage gains of 50V/V and 20V/V, respectively.
A digital SIGN output indicates direction of current flow, so the user can utilize the full ADC input range for measuring both charging and discharging currents.
The MAX9928/MAX9929 are fully specified over the -40°C to +125°C automotive temperature range, and available in 6-bump UCSP™ (1mm x 1.5mm) and 8-pin µMAX® packages. The UCSP package is bump-to-bump compatible with the MAX4372_EBT.
MAX9928, MAX9929关键特性
MAX9928, MAX9929应用/使用
通用系统/板级电流监视
便携式/电池供电系统的充/放电电流监测
笔记本电脑
精密电流源
智能电池组/充电器
智能蜂窝电话
超级电容充电/放电
