Current-Sense Amplifiers Provi
新品快讯
30人已加入
Current-Sense Amplifiers Provide a Wide -0.1V to +28V Input Range for Charge/Discharge Current Monitoring
  • The MAX9928/MAX9929 are low-cost, bidirectional current-sense amplifiers.
  • These devices feature a wide, -0.1V to +28V, input common-mode range, enabling them to monitor deeply discharged batteries and supercapacitors.
  • To provide this wide Vcm, they employ a unique architecture that offers true ground sensing and high-side current sensing in the same IC, allowing both unidirectional and bidirectional (charge/discharge) current monitoring.
  • The MAX9928/MAX9929 are ideal for battery-powered, handheld devices and the emergency backup supplies used in hybrid cars.
SUNNYVALE, CA—September 29, 2008—Maxim Integrated Products (PINK OTC MARKETS: MXIM) introduces the MAX9928/MAX9929 low-cost, current-sense amplifiers for monitoring charge and discharge currents. These devices use a rail-to-rail input stage to achieve a wide, -0.1V to +28V, input common-mode range. This unique architecture offers true ground sensing and high-side current sensing in the same IC with unidirectional or bidirectional (charge/discharge) current-monitoring capability. This is useful for monitoring batteries in deep discharge, as well as the supercapacitors that are commonly used as emergency backup supplies in hybrid cars. Consuming only 20µA of quiescent current from an independent, +2.5V to +5.5V supply voltage, the MAX9928/MAX9929 are also ideal for battery-powered handheld devices.
These precision amplifiers have less than 400µV of offset voltage, and include on-chip, laser-trimmed, gain-setting resistors for better than 1% gain accuracy. The MAX9928 is a current-output device and is available in two transconductance gain options: 2µA/mV and 5µA/mV. The user is free to select the output resistor to convert the current to a voltage to match the input range of an ADC. The MAX9929 is a voltage-output device with fixed-gain options of 20V/V and 50V/V.
Both devices include a digital sign output that indicates the direction of current flow, allowing the user to maximize the output-voltage swing and utilize an ADC's full input range for measuring charge and discharge currents. An internal comparator uses low offset voltage and hysteresis to ensure that the direction of the sign bit is correct and unambiguous.
The MAX9928/MAX9929 are fully specified over the -40°C to +125°C automotive temperature range, and are available in tiny, 1mm x 1.5mm, 6-bump UCSP™ and 8-pin µMAX® packages. Prices start at $0.85 (1000-up, FOB USA).
Maxim Integrated Products is a publicly traded company that designs, manufactures, and sells over $2 billion of high-performance semiconductor products annually. It was founded over 25 years ago with the mission to deliver innovative analog and mixed-signal engineering solutions that add value to its customers' products. To date, Maxim has developed over 5800 products serving the industrial, communications, consumer, and computing markets.
  • 相关推荐
  • 热点推荐
  • A
