MAX5403, MAX5404, MAX5405双路、25
新品快讯
30人已加入
MAX5403, MAX5404, MAX5405双路、256抽头、低漂移、数字电位器,10引脚µMAX封装
概述
The MAX5403/MAX5404/MAX5405 is a family of dual linear taper digital potentiometers. Each device has one 3-terminal potentiometer and one 2-terminal variable resistor (Figure 1). The MAX5403/MAX5404/MAX5405 operate from +2.7V to +5.5V single-supply voltages and use an ultra-low supply current of 0.1µA. These devices also provide glitchless switching between resistors taps as well as a convenient power-on reset (POR) that sets the wiper to the midscale position at power-up. The potentiometer consists of a fixed resistor with a wiper contact that is digitally controlled through a 3-wire serial interface and has 256-tap points. It performs the same function as a discrete potentiometer or variable resistor.
These parts are ideal for applications requiring digitally controlled resistors. Three resistance values are available: 10kΩ (MAX5403), 50kΩ (MAX5404), and 100kΩ (MAX5405). A nominal resistor-temperature coefficient of 35ppm/°C end-to-end and 5ppm/°C ratiometric make the MAX5403/MAX5404/MAX5405 ideal for applications requiring low temperature-coefficient variable resistors, such as adjustable-gain circuit configurations.
The MAX5403/MAX5404/MAX5405 are available in a 10-pin µMAX® package. Each device is guaranteed over the extended industrial temperature range (-40°C to +85°C).
关键特性
  • 10-Pin µMAX Small Footprint Package
  • 256-Tap Positions
  • Ultra Low 0.1µA Supply Current
  • +2.7V to +5.5V Single-Supply Operation
  • Low End-To-End Temperature Coefficient: 35ppm/°C
  • Low Ratiometric Temperature Coefficient: 5ppm/°C
  • Power-On Reset: Wiper Goes to Midscale (Position 128)
  • Glitchless Switching Between Resistor Taps
  • 3-Wire SPI™-Interface Compatible
  • 10kΩ/50kΩ/100kΩ Resistor Values
  • 应用/使用
    可调节的电压基准
  • 阻抗匹配
  • LCD屏调节
  • 低失调可编程增益放大器(PGA)
  • 替代机械电位器
  • 可编程滤波器、延时、时间常数
  • 音量控制
