MAX5100 满摆幅电压输出,+2.7V至+5.5V、低功
新品快讯
29人已加入
MAX5100 满摆幅电压输出,+2.7V至+5.5V、低功耗、四路、并行8位DAC
The MAX5100 parallel-input, voltage-output, quad 8-bit digital-to-analog converter (DAC) operates from a single +2.7V to +5.5V supply and comes in a space-saving 20-pin TSSOP package. Internal precision buffers swing Rail-to-Rail, and the reference input range includes both ground and the positive rail. All four DACs share a common reference input.
The MAX5100 provides double-buffered logic inputs: four 8-bit buffer registers followed by four 8-bit DAC registers. This keeps the DAC outputs from changing during the write operation. An asynchronous control pin, active-low LDAC , allows for simultaneous updating of the DAC registers. The MAX5100 features a shutdown mode that reduces current to 1nA, as well as a power-on reset mode that resets all registers to code 00 hex on power-up.
MAX5100关键特性
  • +2.7V to +5.5V Single-Supply Operation
  • Ultra-Low Supply Current
    • 0.4mA while Operating
    • 1nA in Shutdown Mode
  • Ultra-Small 20-Pin TSSOP Package
  • Ground to VDD Reference Input Range
  • Output Buffer Amplifiers Swing Rail-to-Rail
  • Double-Buffered Registers for Synchronous Updating
  • Power-On Reset Sets All Registers to Zero
  • MAX5100应用/使用
  • 数字增益与失调控制
  • 便携式仪表
  • 功率放大器偏置控制
  • 可编程衰减器
    MAX5100 Functional Block Diagram
    • 相关推荐
    • 热点推荐
