MAX4265, MAX4266, MAX4267, MAX
新品快讯
29人已加入
MAX4265, MAX4266, MAX4267, MAX4268, MAX4269, MAX4270 超低失真、单电源、300MHz运算放大器,带有使能端
The MAX4265–MAX4270 ultra-low distortion, voltage-feed-back op amps are capable of driving a 100Ω load while maintaining ultra-low distortion over a wide bandwidth. They offer superior spurious-free dynamic range (SFDR) performance: -90dBc at 5MHz and -59dBc at 100MHz (MAX4269). Additionally, input voltage noise density is 8nV/ while operating from a single +4.5V to +8.0V supply or from dual ±2.25V to ±4.0V supplies. These features make the MAX4265–MAX4270 ideal for use in high-performance communications and signal-processing applications that require low distortion and wide bandwidth.
The MAX4265 single and MAX4268 dual amplifiers are unity-gain stable. The MAX4266 single and MAX4269 dual amplifiers are compensated for a minimum stable gain of +2V/V, while the MAX4267 single and MAX4270 dual amplifiers are compensated for a minimum stable gain of +5V/V.
For additional power savings, these amplifiers feature a low-power disable mode that reduces supply current and places the outputs in a high-impedance state. The MAX4265/MAX4266/MAX4267 are available in a space-saving 8-pin µMAX® package, and the MAX4268/MAX4269/MAX4270 are available in a 16-pin QSOP package.
MAX4265, MAX4266, MAX4267关键特性
  • Operates from +4.5V to +8.0V
  • Superior SFDR with 100Ω Load
    • -90dBc (fC = 5MHz)
    • -59dBc (fC = 100MHz)
  • 35dBm IP3 (fC = 20MHz)
  • 8nV/ Voltage Noise Density
  • 100MHz 0.1dB Gain Flatness (MAX4268)
  • 900V/µs Slew Rate
  • ±45mA Output Driving Capability
  • Disable Mode Places Outputs in High-Impedance State
    MAX4268, MAX4269, MAX4270应用/使用
  • 基站放大器
  • 高频ADC驱动器
  • 高频信号处理
  • 高速DAC缓冲器
  • 中频放大器
  • 射频电信应用
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
