MAX5150, MAX5151 低功耗、双路、13位、电压
新品快讯
30人已加入
MAX5150, MAX5151 低功耗、双路、13位、电压输出DAC,串行接口
The MAX5150/MAX5151 low-power, serial, voltage-output, dual 13-bit digital-to-analog converters (DACs) consume only 500µA from a single +5V (MAX5150) or +3V (MAX5151) supply. These devices feature Rail-to-Rail output swing and are available in a space-saving 16-pin QSOP package. To maximize the dynamic range, the DAC output amplifiers are configured with an internal gain of +2.
The 3-wire serial interface is SPI™/QSPI™ and MICROWIRE™ compatible. Each DAC has a double-buffered input organized as an input register followed by a DAC register, which allows the input and DAC registers to be updated independently or simultaneously with a 16-bit serial word. Additional features include programmable shutdown (2µA), hardware-shutdown lockout, a separate reference voltage input for each DAC that accepts AC and DC signals, and an active-low clear input (CL) that resets all registers and DACs to zero. These devices provide a programmable logic pin for added functionality, and a serial-data output pin for daisy-chaining.
MAX5150, MAX5151关键特性
  • 13-Bit Dual DAC with Internal Gain of +2
  • Rail-to-Rail Output Swing
  • 16µs Settling Time
  • Single-Supply Operation:
    • +5V (MAX5150)
    • +3V (MAX5151)
  • Low Quiescent Current:
    • 500µA (normal operation)
    • 2µA (shutdown mode)
  • SPI/QSPI and MICROWIRE Compatible
  • Available in Space-Saving 16-Pin QSOP Package
  • Power-On Reset Clears Registers and DACs to Zero
  • Adjustable Output Offset
  • MAX5150, MAX5151应用/使用
  • 数字增益与失调控制
  • 通用产品
  • 工业过程控制
  • 微处理器控制系统
  • 运动控制
  • 远端工业控制
    MAX5150, MAX5151功能原理框图
    MAX5
    功能原理框图
    • 相关推荐
    • 热点推荐
    • MAX5
