MAX4111, MAX4121, MAX4221 缓冲驱动
新品快讯
29人已加入
MAX4111, MAX4121, MAX4221 330MHz、缓冲驱动视频交叉点开关芯片
 The MAX4111/MAX4121/MAX4221 wideband video switches are optimized for high-definition, broadcast-quality, composite (HDTV, NTSC, PAL, SECAM, and RGB) video switching arrays. Their open-loop buffer amplifiers offer 0.1dB gain flatness to 150MHz. They operate from ±5V supplies and feature differential phase and gain error of only 0.01°/0.01%, respectively. The ultra-low switching glitch (13mV) is positive to avoid confusion with any sync pulse.
Ideal as building blocks in large arrays, these devices feature a constant, high input impedance and a disable function that puts the outputs into a high-impedance state and reduces the operating current to only 250µA. The open-loop architecture allows the outputs to drive capacitive loads without oscillation. Other key features include -92dB crosstalk and -78dB isolation (MAX4121).
The MAX4111/MAX4121/MAX4221 are offered in narrow plastic DIP and SO packages. See the table below for key features:
MAX4111, MAX4121, MAX4221关键特性
  • -3dB Bandwidth of 330MHz
  • 0.1dB Gain Flatness of 150MHz
  • 700V/µs Slew Rate
  • 0.01°/0.01% Differential Phase/Gain
  • Low Power: 5.5mA Max
  • -92dB Crosstalk and -78dB Off Isolation at 30MHz
  • High-Z Outputs when Disabled
  • 3pF Input Capacitance
  • Ultra-Low Switching Glitch
  • On-Board Control Logic
  • MAX4111, MAX4121, MAX4221应用/使用
  • 广播/HDTV级彩色信号多路复用
  • 数据采集
  • 图形彩色信号切换
  • 射频与中频路由
  • 电信路由
  • 视频切换及交叉矩阵开关
    • 相关推荐
    • 热点推荐
