MAX3509 CATV上行放大器(含应用电路和参数资料)
新品快讯
29人已加入
MAX3509概述
The MAX3509 is a programmable power amplifier for use in CATV upstream applications. The device outputs up to 66dBmV QPSK through a 1:1 transformer. It features variable gain controlled by a 3-wire digital serial bus. Gain control is available in 1dB steps. The device operates over a 5MHz to 65MHz frequency range.
The MAX3509 offers a transmit-disable mode, which places the device in a high-isolation state for use between bursts in TDMA systems. In this mode, all analog functions are shut down, minimizing output noise and power consumption. When entering and leaving transmit-disable mode, transients are kept to 25mV nominal at full gain. In addition, supply current is reduced to 7.8mA.
An additional power-down mode is available. Shutdown mode disables all circuitry and reduces current consumption to less than 1µA.
The MAX3509 is available in a 20-pin TSSOP-EP package for the extended-industrial temperature range(-40°C to +85°C).
MAX3509关键特性
  • Ultra-Low Power-Up/Down Transients, 25mV (typ) at 66dBmV Output
  • Single-Supply Operation
  • Output Level Ranges from <12dBmV to 67dBmV (QPSK)
  • Gain Programmable in 1dB Steps
  • Low Transmit Output Noise Floor: -41dBmV (160kHz BW)
  • Low Transmit-Disable Output Noise: -70dBmV
  • Shutdown Mode
  • MAX3509应用/使用
    电缆调制解调器
  • CATV基础结构
  • CATV状态监视
  • OPENCATV机顶盒
  • 线缆电话
    MAX3509应用电路
    典型工作电路
    • 相关推荐
    • 热点推荐
