MAX8856 由USB/AC适配器为单节Li+电池充电,为
新品快讯
29人已加入
MAX8856 USB/AC Adapter, Li+ Linear Battery Charger with Integrated 50mΩ Battery Switch in TDFN
MAX8856 由USB/AC适配器为单节Li+电池充电,为手持设备提供快速充电器件
The MAX8856 complete 1-cell Li+ battery charge-management IC operates from either a USB port or AC adapter. It integrates a battery disconnect switch, current-sense circuit, PMOS pass element, and thermal-regulation circuitry, while eliminating the external reverse-blocking Schottky diode, to create a simple and small charging solution. The charging sequence initiates from power-OK indication, through prequalification, fast-charge, top-off charge, and finally charging-complete indication for single-cell Li+ batteries. Charging is controlled using constant current, constant voltage, or constant die-temperature (CCCVCTJ) regulation for safe operation in handhelds.
Two logic inputs (active-low EN1, active-low EN2) select suspend mode, 100mA, 500mA, or ≤ 1A input current limits to comply with USB requirements. Proprietary thermal-regulation circuitry limits the die temperature to +100°C to prevent excessive heat on the system PC board. Additional safety features include an NTC thermistor input (THM) to protect the battery. A 3.5V to 4.2V SYS output, in conjunction with the low-RDSON battery switch, powers the system even when the battery is deeply discharged or not installed. The IC also offers a +3.3V/500µA output (VL), a charging status flag (active-low CHG), and an input-supply detection flag (active-low POK). The MAX8856 operates from a +4.25V to +5.5V supply and includes undervoltage lockout below +3.4V and overvoltage protection up to +14V.
关键特性
  • Small, 3mm x 3mm Thermally Enhanced TDFN Package (0.8mm max height)
  • USB-Compliant Suspend Mode (20µA)
  • Selectable 100mA, 500mA, and Up to 1A Input Current Limits
  • USB or AC Adapter Input
  • +6V to +14V Input Overvoltage Protection
  • Input UVLO Below +4V Rising (3.5V Falling)
  • Automatic Current Sharing Between Battery Charging and System
  • Die Temperature Regulation (+100°C)
  • Low Dropout Voltage, 250mV at 0.5A
  • NTC Thermistor Input
  • Charge Status and Input-Supply Detection Flags
    应用/使用
    蜂窝电话、智能电话、PDA
  • 数码相机、MP3播放器
  • USB配件, 充电架和坞站
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
