MAX7401, MAX7405 八阶、低通、贝塞尔、开关电
新品快讯
29人已加入
MAX7401, MAX7405 八阶、低通、贝塞尔、开关电容滤波器
MAX7401, MAX7405概述
The MAX7401/MAX7405 8th-order, lowpass, Bessel, switched-capacitor filters (SCFs) operate from a single +5V (MAX7401) or +3V (MAX7405) supply. These devices draw only 2mA of supply current and allow corner frequencies from 1Hz to 5kHz, making them ideal for low-power post-DAC filtering and anti-aliasing applications. They feature a shutdown mode that reduces supply current to 0.2µA.
Two clocking options are available on these devices: self-clocking (through the use of an external capacitor) or external clocking for tighter corner-frequency control. An offset adjust pin allows for adjustment of the DC output level.
The MAX7401/MAX7405 Bessel filters provide low overshoot and fast settling. Their fixed response simplifies the design task to selecting a clock frequency.
MAX7401, MAX7405关键特性
  • 8th-Order, Lowpass Bessel Filters
  • Low Noise and Distortion: -82dB THD + Noise
  • Clock-Tunable Corner Frequency (1Hz to 5kHz)
  • 100:1 Clock-to-Corner Ratio
  • Single-Supply Operation
    • +5V (MAX7401)
    • +3V (MAX7405)
  • Low Power
    • 2mA (Operating Mode)
    • 0.2µA (Shutdown Mode)
  • Available in 8-Pin SO/DIP Packages
  • Low Output Offset: ±5mV
    MAX7401, MAX7405应用/使用
    ADC抗混叠
  • 气囊电子装置
  • CT2基站
  • DAC后置滤波
  • 语音处理
    MAX7401, MAX7405典型应用电路
  • 打开APP阅读更多精彩内容
    • 相关推荐
    • 热点推荐
