MAX8879 用于背光/闪光灯/RGB LED驱动的安全定时器
MAX8879概述
The MAX8879 features an internally trimmed reference to set the maximum LED current. An I²C serial port is used for on/off control and setting the LED currents in 32 linear steps for main, sub/RGB, and movie. When using the RGB indicator, the I²C port provides 32k colors and programmable ramp-up/down rates. The camera flash for flash-mode operation is enabled by an active-low signal on the active-low FSH pin. A safety timer is activated on the falling edge of active-low FSH, which has an I²C-adjustable (programmable) period of no timer, 0.5s, 1.0s, or 2.0s (default). If the safety timer period expires, both flash and movie modes are disabled.
MAX8879关键特性
Guaranteed 610mA Continuous Drive Capability
- 4 LEDs at 30mA Each for Main Display
- 3 LEDs at 30mA Each for Sub or RGB
- 400mA Total for Flash
2-Wire I²C Serial Port
- 5-Bit (32-Step) Linear Dimming
- 32k Colors
- Ramp-Up/Down Rates
92% Peak/83% Avg Efficiency (PLED/PBATT)
Adaptive 1x/1.5x/2x Mode Switchover
0.3% (typ) LED Current Accuracy and Matching
Low Input Ripple and EMI
Low 0.1µA Shutdown Current
Output Overvoltage Protection
I²C Programmable Flash Safety Timer
Thermal Derating Function Protects LEDs
24-Pin, 4mm x 4mm Thin QFN Package
MAX8879应用/使用
蜂窝电话与智能电话
LED显示器,多达11个LED
PDA、数码相机、便携式摄像机
MAX8879 pdf datasheet
