terawins T102
视频技术
16人已加入
terawins T102
The T102 is a highly integrated All-in-one Visual Processor that provides major cost saving solution for the portable applications. T102 has built-in Double high performance ADCs, TCON, Triple DACs, Scaling Machine with sophisticated upscaling and downscaling algorithms. The Innovative integrated “Frame-Buffer-Less” De-interlacer can significantly reduce system cost. The T102 also integrates On Screen Display engine with 1K-word of SRAM. The device can interface to an external micro-controller through 2-wire serial bus interface.
Application
  • Portable AV system
  • Portable TV set
  • Progressive Car TV set
  • Features
    • Cost Effective Highly Integrated Double ADC + ITU656/601 Decoder + 2D Video Decoder + OSD + Scaler + TCON + DAC
    • Integrates 9-bit Double Analog to Digital Converters (ADC) & Phase Locked Loop (PLL)
    • Scaler supports 2-D adaptive intra-field de-interlacer and non-linear 16:9 aspect ratio.
    • Built-in Pre-amp, mid-level & ground clamp circuit
    • Automatic Clamp Control for CVBS, Y and C
    • Max Input configuration up to 6xCVBS, 3xS-video
    •  ITU656/601 Decoder with digital input ports for standard ITU656/601 input data
    • Chroma Enhancer supports
      -C- Supports DCTI, Saturation and Hue adjustment.
    • 2.5v & 3.3V operating voltage
    • RGB Triple DAC output
    • Built-in On Screen Display Engine
      - 1K-word OSD SRAM memory
      - Supports text or bitmap modes
      - Supports character blinking, overlay, shadow and border functions
      - Fully programmable character mapping
      - Supports alpha blending & Zoom-in/Zoom-out function
      - Optional fonts can be stored in off-chip serial EEPROM
    • Direct interface to a (27.0MHz) Crystal
    • Supports 2-wire (normal speed) or 4-wire (high speed) modes
    • Pulse Width Modulation Outputs
    • Package: 100-pin LQFP
