terawins T106
视频技术
16人已加入
terawins T106
The T106 is a highly integrated All-in-one Visual Processor that provides major cost saving solution for the portable applications. T106 has built-in TCON, Triple DACs, Scaling Machine with sophisticated upscaling and downscaling algorithms. The Innovative integrated “Frame-Buffer-Less” De-interlacer can significantly reduce system cost. The T106 also integrates On Screen Display engine with 1K-word of SRAM. The device can interface to an external micro-controller through 2-wire serial bus interface.
Application
  • Portable AV system
  • Portable TV set
  • Progressive Car TV set
Features
  • Programmable Timing Controller (Tcon) for Car TV applications
  • Scaler supports 2-D adaptive intra-field de-interlacer and non-linear 16:9 aspect ratio.
  • ITU656 Decoder with digital input ports for standard ITU656 input data.
  • Separate Luminance and Chroma Enhancer supports
    -Y-DLTI, Black Level Expansion, Contrast and Brightness adjustment
    -C- Supports DCTI, Saturation and Hue adjustment.
  • 2.5v & 3.3V operating voltage
  • RGB Triple DAC output
  • Built-in On Screen Display Engine
    - 1K-word OSD SRAM memory
    - Supports text or bitmap modes
    - Supports character blinking, overlay, shadow and border functions
    - Fully programmable character mapping
    - Supports alpha blending & Zoom-in/Zoom-out function
  • Direct interface to a (27.0MHz) Crystal
  • Supports 2-wire (normal speed) or 4-wire (high speed) modes
  • Design For Testability
    - Scan chain insertion
    - Separated analog & digital test modes
  • Pulse Width Modulation Outputs
  • Package: 100-pin LQFP
  • 打开APP阅读更多精彩内容
