terawins T515A
视频技术
16人已加入
terawins T515A
The T515A is a low-power mixed signal SDTV Video Decoder that provides major cost saving solution for the LCD applications. With built-in high performance Dual ADCs, Chroma Phase Locked Loop, Automatic Sync Tip Slicer and 2-D Comb Filter, T515 can separate Luma and Chrom signal as true as no cross luma and cross chroma effects. With effective signal demodulator, Cb/Cr data can be obtained from Chroma signal. ITU-R BT.656 data or 8 bit 4:2:2 data with sync signal are selected as data output.
Features
SDTV system video Decoder
  • 2D Comb Filter video Decoder
  • Accepts NTSC(M), PAL(B,D,G,H,I,N,CN), and SECAM video data
  • Accepts Composite and S-video signals
  • Versatile VBI Data Decoder
  • Supports Close Caption, Wide Screen Signaling and Teletext
  • Cost Effective Highly Integrated Dual ADC + 2D Video Decoder + VBI Data Decoder
  • Integrates 9-bit Dual Analog to Digital Converters (ADC) & Phase Locked Loop (PLL)
  • Multi-standard color decoder with 2D adaptive comb filter
  • Innovative and flexible design to reduce total system cost
  • Power down mode available
Triple 9-bit Analog to Digital Converters (ADC)
  • 27MSPS Conversion Rate
  • Built-in Pre-amp, mid-level & ground clamp circuit
  • Automatic Clamp Control  for CVBS, Y and C
  • Programmable Static Gain Control  or Automatic Gain Control for CVBS or Y/C
  • Max Input configuration up to 4xCVBS, 2xS-video inputs
Digital Video Enhancement
  • Separate Luminance and Chroma Enhancer
  • Y Supports Luminance Peaking, Contrast and Brightness adjustment
  • C Supports DCTI, Saturation and Hue adjustment.
  • Horizontal active data adjustment and black color insertion
  • Flexible Data Output Format
  • 2 configurable output modes:
  • 27Mhz 8-bit ITUR BT.-656 mode
  • 27Mhz 8-bit 4:2:2 data with sync signals
System Interface
  • Crystal Oscillator Circuit
  • Direct interface to a (27.0MHz) Crystal
  • Also provide a buffered clock output for ITU656 decoder.
