DS2741 Current Monitor and Acc
新品快讯
29人已加入
DS2741 Current Monitor and Accumulator with Integrated Sense Resistor
DS2741概述
The DS2741 current monitor/accumulator is a complete current-sensing, measuring, and accumulation device tailored for cost-sensitive, battery-powered applications in a small 3mm x 3mm TDFN package. As a result, the DS2741 is a key component in battery-charge control and remaining capacity-estimation applications.
Through its I²C interface, the DS2741 gives the host system access to current measurement and accumulation registers. The 7-bit slave address is factory programmable, allowing up to 128 devices to be individually addressed by the host system.
DS2741关键特性
  • Complete, Low-Cost, Integrated Current-Sensing and Accumulation Solution with Serial Digital Output
  • On-Board 38mΩ Sense Resistor
  • Current Measurement:
    • Signed 10-Bit Bidirectional Measurement
    • ±2.5A Dynamic Range
    • 1% Error at +25°C
    • 2% Error Over Temperature
  • Current Accumulation:
    • 0.247mAhr LSB
    • ±8.1Ahrs Full-Scale Range
  • Industry-Standard I²C Interface with Factory-Programmable Slave Address
  • 2.5V to 4.5V Single-Supply Operation
  • Low-Power Consumption:
    • Active Current: 60µA (typ)
    • Sleep Current: 1µA (typ)
  • -20°C to +70°C Operating Range
  • 14-Pin TDFN (3mm x 3mm x 0.8mm)
  • DS2741 pdf datasheet (Current Monitor and Accumulator with Integrated Sense Resistor)
    DS2741应用/使用
  • Battery Monitor/Rechargers
  • 蜂窝电话
  • PDA
    DS2741应用电路
    DS
    • 相关推荐
    • 热点推荐
    • DS
