MAX860, MAX861 50mA、频率可选的开关电容电压变换器
MAX860, MAX861概述
The MAX860/MAX861 charge-pump voltage converters invert input voltages ranging from +1.5V to +5.5V, or double input voltages ranging from +2.5V to +5.5V. Because of their high switching frequencies, these devices use only two small, low-cost capacitors. Their 50mA output makes switching regulators unnecessary, eliminating inductors and their associated cost, size, and EMI. Greater than 90% efficiency over most of the load-current range, combined with a typical operating current of only 200µA (MAX860), provides ideal performance for both battery-powered and board-level voltage-conversion applications.
A frequency-control (FC) pin provides three switching-frequencies to optimize capacitor size and quiescent current and to prevent interference with sensitive circuitry. Each device has a unique set of three available frequencies. A shutdown (active-low SHDN) pin reduces current consumption to less than 1µA. The MAX860/MAX861 are suitable for use in applications where the ICL7660 and MAX660's switching frequencies are too low. The MAX860/MAX861 are available in 8-pin µMax and SO packages.
MAX860, MAX861 关键特性
8-Pin, 1.11mm High µMAX Package
Invert or Double the Input Supply Voltage
Three Selectable Switching Frequencies
High Frequency Reduces Capacitor Size
87% Efficiency at 50mA
200µA Quiescent Current (MAX860)
1µA Shutdown Supply Current
600mV Voltage Drop at 50mA Load
12Ω Output Resistance
MAX860, MAX861 pdf datasheet
MAX860, MAX861 应用/使用
手持式仪表(PDA、掌上电脑)
接口供电
医疗仪器
运算放大器电源
便携式计算机
MAX860, MAX861 应用电路
 典型工作电路 |
